Traxxas Slash HELP!
Traxxas Slash HELP!
Hey RC Tech,
I was out running my Slash and it just cut off when I jumped a curb.
So, I took off the body to see what the problem was and I figured out that the '+' and '-' wire has been seperated.
I attatched some photos of it to show how it's been seperated.
Now, how hard is it to just buy a new wire and attatch them?
And what exactly do I have to buy?
Any help would be appreciated, THANK YOU!!
Bad solder joint. Grab your soldering iron and reattach it.
R/C Tech Elite Member
Hey RC Tech,
in the second pic, is that neg wire separated inside?
for the deans;
clean the solder from the deans plug, grab a metal file (or dremel with sanding drum) scuff up where your going to resolder, blow off, rubbing alcohol and a q-tip, clean it, let dry, re-tin, re-solder! i do this to ensure the solder has something to grab onto, also i flatten the wires a bit so the solder flows through easier.
for the deans;
for the deans;
for the deans;
