Team Durango DESC210R
#183
Tech Legend
Trader Rating: 51 (100%+)
Good thing you ordered it for me. You beat me to it. I will plenty of time to have it ready for October indoor season to start.
#184
So from what I'm reading and seeing this new truck will pretty much use most of the same parts as the 210 buggy correct? I'm not really the best at setting these up and it will be great to finally have 2 cars that are really similar. Also, I'm thinking that personally keeping parts in stock will be easier now since they both share so much right?
#185
#186
^ HAHAHAHA ok thanks man
#187
The Desc210r shares rear hubs with the the ST and 210 buggy. Front hubs and carries are shared between the ST and 2wd SC truck but are different than the 4wd SC.
#189
Randy. you seem up on this truck, will the trans used in this truck be the same as the buggy? if this is true, I can start ordering trans parts for stock in my box's.
#190
#191
Hey Tim, yes the both the St and 2wd SC truck share the 210 trans and parts.
#192
I'm really sorry for the dumb question but I'm confused on something here. I bought my 210 used and built so this might explain some of my confusion since I did not build it. Why is it that I'm seeing RM setups with the motor on the right and or left side of the truck? I thought when in rear mode the motor was on the left of the truck and in MM the motor is on the right? Again, sorry if this is just something I should know by now.
#193
#194
Ah ok thank you. After reading your post I did a little more research and it makes sense now
