Buggy Cutting Out
Buggy Cutting Out
I need some help figuring out why my buggy is cutting out on me. Randomly it will loose all power to the wheels but my steering will still work. A second later everything is working again. Other times my buggy will just randomly turn sharply on it's own to one direction and then again, a second later and it's fine. I would love to just start replacing electronics to figure out what's wrong but that's some costly trouble shooting. Here's my setup.
TLR 22
Ballistic 7.5
Tekin RS
Spektrum S6040
Gens Ace 5000mAh 40C
Futaba 4PL
Futaba R2104GF
Thanks for any help you can give!
TLR 22
Ballistic 7.5
Tekin RS
Spektrum S6040
Futaba 4PL
Futaba R2104GF
Same thing happened to me. One of my motor wires was not making a solid connection. Looked like it was, but when I gave it a light tug, came apart in my hand. Check your connections, be sure to give them all a tug and make sure they're really on there.
Yes it could. You must understand that the BEC powers the servo, radio, and sensors on the motor along with any other thing plugged into the receiver like your PT.
Try adding a glitch buster to your radio. Spektrum SPM1600 is the part #.
It's a new build although the motor was bought used from here.
yes to a glitch buster but also double check that you have the servo dead centered it should be on a 22 one notch to the right while looking at the face of it. If you have it to far one way or the other then you have to set your sub trim to high and it will draw crazy amps.
Also I bought the servo used and the previous owners cut the wires short. Could a poor wiring job to the servo cause it?
Any advice on how to fix a poorly wired servo? I don't have a lot of wire left to work with, maybe 1/2 inch or so.
