RC10T4.1 Thread.
Old 12-29-2011 | 09:04 AM
  #46
I use lint-free industrial paper towels made by Caterpiller. They're clean, disposable, and 100% free for me. To clean the surfaces I've used denatured alcohol, tried motor spray, as well as lacquer thinner. Alcohol seems to work the best.
I think my problem is my wiring. I don't leave much slack and I think when I land on my front end that loosens up the esc. I could just reverse the battery pack and that would give the wires more slack, but I despise big loops and excess wire.
Hinecken is offline
Old 12-29-2011 | 09:27 AM
  #47
zeakemedia's Avatar
I actually have tried four or five different kinds of double sided tape for my ESC and only one has worked. Can't remember where I got it but remember that the ESC heats up unlike other pieces that are "stuck" to the vehicle. The tape has to be heat resistant. Also after I clean the area I let it sit for a while and then wipe off with a paper towel before applying the tape.
Blake
zeakemedia is offline
Old 12-30-2011 | 07:14 AM
  #48
Any experiences with HobbyPartz servos? The rtr servo is complete garbage, but I'm not trying to break the bank. Also, can someone explain the difference between a digital and analog servo?
Hinecken is offline
Old 12-30-2011 | 07:30 AM
  #49
Cain's Avatar
Tech Legend
I use goo gone cleaner to spray down surfaces. It actually feels oily going on, but once I let it sit and then wipe the surface allows really good adhesion.
The servo tape I now use is this clear stuff that has a red wrapper on it. Can't remember what it is exactly but man that stuff is strong.
Cain is offline
Old 12-30-2011 | 09:06 AM
  #50
I use Parma tape. Thats the clear tape with red backing, it's the best.
Harry Sachs is offline
Old 12-30-2011 | 09:40 AM
  #51
Cain's Avatar
Tech Legend
+1 thats the stuff!
Cain is offline
Old 12-30-2011 | 10:31 AM
  #52
vulcanbomber's Avatar
Default +8 mm chassis.
I am not famaliar with the Roar/Ifmar rules but is the +8mm chassis for the b4.1 legal for the T4.1? Im just curious about it. I am sure its been asked i just cant find the thread through search.
vulcanbomber is offline
Old 12-30-2011 | 11:23 AM
  #53
racer1812's Avatar
Super Moderator
The +8 B4.1 chassis would make a T4 11mm shorter than stock. Not sure about the rules but why would you want a shorter truck? Not saying it might not work, just wonder why you want it.
racer1812 is offline
Old 12-30-2011 | 09:12 PM
  #54
does anyone know what the dimensions of the biggest servo you can fit in the T4? I'm looking at one with dimensions of 41.3x21.2x40. It's a hobbypartz Solar Servo D771.
GatorsUF is offline
Old 12-30-2011 | 09:20 PM
  #55
did you get your truck yet?
No one has an opinions or answers on a question I asked a few days ago?
Regarding fluid in a gear dif. I remember from way back in my 1/8th days we used to tune with different fluids in the diffs. Why is it when I ask about running different weight fluid in this gear diff do people look at me like I'm crazy and tell me to stick with the grease? Can this gear diff not be tuned in a similar fashion? If so, what weight fluid would be a good baseline equal to the grease from the factory? I've been told 3k is similar.
Hinecken is offline
Old 12-30-2011 | 09:30 PM
  #56
ya man.. all put together for the most part.. working on painting the body and waiting for wheels to come in. Check out those servo specs on hobbypartz for the solar servo. Seems awesome if it holds up.
GatorsUF is offline
Old 12-30-2011 | 10:01 PM
  #57
Just curious. No plans to use it. Just wondering is all.
Old 12-30-2011 | 11:00 PM
  #58
SirKarnage's Avatar
Associated DS1015 servo, (41.8x 20.6 x 39.6)
which I know will fit in a T4:
The Solar seems only a hair wider, so I would take the stab and give it a shot.
SirKarnage is offline
Old 12-30-2011 | 11:04 PM
  #59
SirKarnage's Avatar
Originally Posted by SirKarnage
Is anyone Doing the hex conversion for the B4 front end on to your T4?
I just ordered the parts, plan to use the axels and spacers properly to just run my current Rulux rears without the hex, just the pin like the current rears are on the T4.
If you have any experience with this, post up!
Parts came in, just need to grind the cvd ball end off the axels. Will post up results and a walk through if anyone is interested.
Old 12-30-2011 | 11:27 PM
  #60
Cummins Driver's Avatar
Figured id post some pictures of my T4. I havent had it long. Its a little different than most of the talk in here because I bought mine with intentions of finding a good basher that also handled well. I have been running stampede's for years and decided i wanted to try a stadium truck after my last stampede. I bought this T4 and love it so far. I have broken a couple small things, but i feel after some little upgrades it will be a really strong truck. The stampede is more durable, but the T4 out handles it by a lot and is much easier to control with brushless power. Not to mention the transmission is whisper quiet and smooth as glass
I also just bought a T4.1 and had plans to sell it, but my wife says she likes it better than her stampede she runs, so its staying too. No pictures of it yet, but here is mine:
Attached Thumbnails RC10T4.1 Thread.-100_2619.jpg   RC10T4.1 Thread.-100_2621.jpg   RC10T4.1 Thread.-100_2626.jpg   RC10T4.1 Thread.-100_2646.jpg
Cummins Driver is offline
