PIT BOX MUST HAVE ITEMS
#61
I have a Plano Phantom Pro for a pit box. Everything but the Simple Green, Tire wash tub, and soldering Iron station fit. I used to put my Hyperion charger inside too, ha ha.
What are you guys using for pit boxes that they don't fit much stuff? a shoe box?
In the old days, I used to keep the bottom drawer filled with NiMH batteries and brushed motors, the box was really heavy back then.
Not to mention the rubber made container full of nothing but tires. I remember I had a hauler bag, a 3 box car carrying bag, the tool box and two rubber mades. AHHH the joys of brushed racing and ni cads.
Now I have almost everything you bring in one of those stanly fat max wheeled containers. (and I still have a ton of room in it )
#62
allen drivers
socket drivers
Integy shock shaft pliers
Integy Quick pit drivers
Integy Quick pit sockets
Spare tips, .050, 1/16th, 1.5mm
Cordless driver for quick pits
Racers Edge diff tool
Racers Edge ball cup tool
Racers Edge shock piston finger drills
Hudy Setup System
Tire Balancer w/clay
Sharpie for labeling tire/compound/insert combinations
Digital Calipers
3 tierod wrenchs - Asoociated, Lundsford, Losi
Losi Ride Height Gauge
Losi Camber Gauge
Losi Shock Tool
Associated stamped shock tools for their cars
Losi shock tools for their cars, diff tool, slipper tool
Dremel (corded) with sanding drum, cutoff wheel, and a carbide cutting bit
Hakko Soldering station
Solder
Flux paste
3rd hand clamps
heat shrink tubing assortment
small cable ties
CRC wire hold down clips
spare deans plugs
spare bullet connectors
simple Green
shock oils 25, 27.5, 30, 32.5, 35, 37.5, 40 weights
Ofna shock stand
Green slime
AE steath diff lube and grease
tire glue w/ rubber bands
glue Tips
thread lock - blue
Rags
Q-tips
motor Spray
tire traction compound
Tire cleaning tub
hobby Knife and spare blades
double sided servo tape
straight lexan scisssors
curved lexan scissors
THS body reamer
needle nose pliers
side cutters
Exacto straight edge ruler
tooth brush
small pick (dirt from screw heads)
Pinions
Paragon pinion caddy
Spare sensor board for motors
Spare sensor cable for motors
Spare fan for ESC
Spare Axle bearings
Spare fasteners, body clips, nuts, wheel pins, etc.
That should be about it....
socket drivers
Hudy Setup System
Digital Calipers
Losi Camber Gauge
Losi Shock Tool
Solder
Flux paste
3rd hand clamps
small cable ties
spare deans plugs
simple Green
Ofna shock stand
Green slime
glue Tips
thread lock - blue
Rags
Q-tips
motor Spray
Tire cleaning tub
THS body reamer
needle nose pliers
side cutters
tooth brush
Pinions
Spare fan for ESC
Spare Axle bearings
#63
#67
Definitely need all of your spare parts. I also have a spare motor with me. Soldering iron, dremel, assorted screws and washers, shock oils, simple green and a wire brush for cleaning tires, motor spray, shop towels, all your tools, and definitely the manuals for all of your cars.
#68
Since this thread has been bumped back up. Most important item:
TP for my bunghole.
TP for my bunghole.
#69
allen drivers
socket drivers
Hudy Setup System
Digital Calipers
Losi Camber Gauge
Losi Shock Tool
Solder
Flux paste
3rd hand clamps
small cable ties
spare deans plugs
simple Green
Ofna shock stand
Green slime
glue Tips
thread lock - blue
Rags
Q-tips
motor Spray
Tire cleaning tub
THS body reamer
needle nose pliers
side cutters
tooth brush
Pinions
Spare fan for ESC
Spare Axle bearings
socket drivers
Hudy Setup System
Digital Calipers
Losi Camber Gauge
Losi Shock Tool
Solder
Flux paste
3rd hand clamps
small cable ties
spare deans plugs
simple Green
Ofna shock stand
Green slime
glue Tips
thread lock - blue
Rags
Q-tips
motor Spray
Tire cleaning tub
THS body reamer
needle nose pliers
side cutters
tooth brush
Pinions
Spare fan for ESC
Spare Axle bearings
You forgot about the Milwaukee Backpack Concrete Vibrating kit. Don't worry, It's easy to forget.
#73
the guys at our local parking lot onroad races are nuts. people rolling out all kind of stuff. shelving units and what not. if you are stating from the start of this thread I think its safe to leave the crystals out.
#75
Everything I need to race, build, maintain one car, fits in a single 55g Stanley tote.
Onroad is a stackable Dewalt roller box.
Airplanes, is the same stanley tote, and a small toolbox of airplane specific stuff.
The shelfs are kinda nonsense. They're just clutter. Toss your unused car under your bench or back in your trunk.
