The HHH chassis is also an option and might be easier to make work with the tork motor. It will also reposition the motor more like the ve8 and allow more battery location options.
Originally Posted by jhassing
(Post 10043968)
okay guys,
I sent an email to Tekno support to ask them what the options for the motor mount were and this is what they said. "The only option is to grind the large lugs off of the Tork motor so it will fit into one of our mounts." What about risk of overheating as a result of the mod? "No risk of overheating. I don't think there is much heat dissipation from the blocks in the first place. As long as your setup is within reason (not running 6s for 20minutes straight for example), it should be fine." Grid away! Or buy another motor. |
(Post 10039513)
Hey Cergai,
Did you find out any more about getting the Tork motor to fit in the v4 chassis? -J |
Hey guys, is this the diff top plate needed to complete the v4 kit conversion?
Hot Bodies Center Differential Mount Cover [HBS67420] |
(Post 10052883)
I'm sold on this upgrade!
(Post 10052883)
congrats. Feel free to post in the HPI Vorza thread, pretty much one stop shop for all D8 style conversions and vorza questions.
hello
converting my vorza with v4 kit. manual is in words...how do you set up the servo? little lost here...servo link is short and i need VERY longer one. did anyone had problem with this? i need pictures!!! not words !!! |
can you take a picture of what you are seeing and post?
Also, a measurement of your link would be helpful too. I am wondering if maybe the D8 nitro setup has a longer link than the vorza. |
