Team Associated RC8.2e Thread
#5536
If you go to Amains website and put rc8.2 in the search bar then go to the last page of 8.2 parts they stock the protek gearbox shims in 1&2mm. Buy both and shim away.
#5537
He is not talking about side to side movement... More so, the bearing being loose after the gearbox is tightened...
#5538
Does the Turnigy 4500mAh 4S 30C hard case fits in the stock RTR? is that enough juice to start racing this RTR?
#5541
Anyone use the SMC 4s lipos? I use there 2s in my b4.2 and have nothing bad to say about them.
#5542
Anyone using RCShox 2-stage pistons? If so, what oils are you using. I have Kysohso light blue springs on at the moment. I know all track conditions are different, but just looking for a starting point.
#5543
how often do you guys run your rc8s? i seem to run 1pack, 5000-6000mah, through mine about 5 times a week.
next time i go bashing i'm going to film it.
i'm getting better and better at jumps and landings, and i love it when i launch FAAAARRR into the air and land nice, smooth, and parallel with the ground as if no jump occurred. it's like when a diver at the summer olympics dives into the water with minimal to no splash.
when i get new batteries, whenever that is, i'm getting two 2s smc lipos, inboard style. i always read good stuff about smc.
but right now i have gforce batteries, which i like well enough. better than the gens ace batteries i had before.
#5544
hey metoo, that's a totally ******' paint job in your avatar. love it. makes me want to try various neon paints. neon green or so would make a great shell color for bashers who drive their rc at night. -- better visibility.
#5545
I bet yello would like this jump! http://youtu.be/1MD_pKl37Ps
#5546
#5547
The bearings shouldn't be loose in the case. If they are you got a bad gear box and you should contact ae for a replacement. Usually there will be slight play in the outdrives and bearings but nothing major.
#5548
So I received my BRAND NEW RC8.2E RTR today… It came with 6 stripped chassis screws, 1 stripped motor mount bolt, 1 missing shock suspension pin and a badly bend rear cv… Called tower and of course they are fantastic as always and it’s being sent back for a replacement. I’m soooooo mad right now!! Such a sour taste in my mouth about AE at the moment… All I own are AE vehicles never expected a company of this quality to have such poor assembly and quality check of their RTR vehicles… This is my first RTR from them; I will be going over this 2nd car with a fine tooth comb after this. If it is anything but perfect, you might just see a race ready factory team B4.2 and RC8.2e for sale… Hello KYOSHO! :flam ing:
#5549
#5550
Did i say how %#&^&%!!! I am?
