E-Truggy  The next big class!!! >
Old 10-05-2011, 03:56 PM
  #46
Nogas's Avatar
We held an electric only event at our club last weekend and we had 11 E truggies. We usually only get about 4 - 5 on regular club days so end up running with nitro or MT's but it was great to have our own class. Ebuggy is going nuts lately with around 12 - 15 every meet and Etruggy is def growing in popularity quickly.
I'm experimenting with low KV / 6S set ups to make longer mains with out pack changes. With a 1350 T8 and a 5000 6S i'm looking good for a 20 minute final. Half hour finals will require 1 pack change but considering most nitro truggies pit atleast 3 times in a half hour final i think i can deal with that.
Heres a few pics of mine
Nogas is offline
Old 10-05-2011, 05:15 PM
  #47
DBL15's Avatar
yeh thats that bloody Truggy i could not catch on the weekends event
here is my new baby Losi 8ight T 2.0 with Electric conversion
RX8 and 2000kv running 4S Reedy lipos and Hitech 7955TG servo
DBL15 is offline
Old 10-05-2011, 05:24 PM
  #48
Nogas's Avatar
haha, i'm the ginger bread man!
Nogas is offline
Old 10-06-2011, 06:37 AM
  #49
kghills's Avatar
Trader Rating: 40 (100%+)
Jason runs a 2000KV on 4S for any event 15min and under with no problems. For 20min mains we switch to a 5S 5450mah hard case and run the EPA at 80%. He thinks he could run 25min. this way but we have never tried.
Keith.
kghills is offline
Old 10-06-2011, 07:38 AM
  #50
Team Tekin
TY@TEAMTEKIN's Avatar
I haven't tried yet but I'm interested to see how long I could potentially run with a 4S 5600 ProTek and my setup dialed back a bit. Can't find out right now since there is SNOW on the ground....
TY@TEAMTEKIN is offline
Old 10-06-2011, 07:44 AM
  #51
Team Tekin
Originally Posted by AZ_Ron
You're guy's track is RIGHT next door to a Sonic??? You BASTARD'S!!!!
R
Haha it was temporarily, that was for the Pro Series event and then it was torn down...
That table was huge, like 40 feet from tip to table, we marked my truggy landing clear at the bottom of the table and it was like 93 feet!
Old 10-06-2011, 12:50 PM
  #52
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
waiting on new lipos, charger, and a bce electric chassis for the 8t 2.0
you guys with the 8t how many are using the stock losi 45tooth plastic spur? i never used off the get go i went with a lightweight 48, but i did have to slightly shim the center diff up a bit. now that im going to use the 45 tooth i dont have to shim it, but then i need to step down the pinion size and the motor wont go any further in past a 14 pinion. no real heat changes or anything with the 45? i was always geared at 15-48
Mr.juarez is offline
Old 10-06-2011, 05:37 PM
  #53
IROC-AR15's Avatar
Trader Rating: 29 (94%+)
Glad to see you started this thread buddy!
Where can a get a cheap lipo?
I'm looking 4s, 5s, and 6s packs
Also is okay to gear 15/50 in my LSP with a 2250KV motor
IROC-AR15 is offline
Old 10-06-2011, 05:53 PM
  #54
AZ_Ron's Avatar
Trader Rating: 16 (100%+)
IROC, check out the website for hobbypartz... they have about the best prices around on LiPo's. I just picked up 3 of the 2s 40C packs for my sc10 for about $30/each.
R
AZ_Ron is offline
Old 10-06-2011, 06:49 PM
  #55
IROC-AR15's Avatar
Are the 5s and 6s 5000mah packs really worth the 79-100 bucks?
Old 10-06-2011, 07:09 PM
  #56
tc5 man's Avatar
Use a 50t/15 pinion, or a "14t pinion" a "50 tooth spur" to me just seems to run better on any truggy compared to a "45t" or a "46t" spur gear in the electrics/motor runs cooler.
tc5 man is offline
Old 10-06-2011, 07:46 PM
  #57
IROC-AR15's Avatar
Was that last post directed at me?
Old 10-06-2011, 10:09 PM
  #58
Mr.juarez's Avatar
thats the thing. the losi kit comes witht he 45 which i never used. i always used the 48 metal spur, but i had to shim it and if i put a 50 then im gonna need like 1/4 in shim so it doesnt hit the chassis, not to mention my 48 is like 3mm away from hitting the lipo tray.
ps. i didnt find a 50 tooth spur on amain, but i did see 43-44-45-47
Old 10-06-2011, 10:36 PM
  #59
tc5 man's Avatar
I use a plastic spur gear on my rc8te and holds up great !
I do have a converted losi eight 1.0 buggy, with the 45t spur i never tried the 50t spur on it but on my losi eight-t, i used a 50t with no issues but it was ran as nitro.
since you cant find a 50t spur for it i guess go with a 47t.
tc5 man is offline
Old 10-07-2011, 06:24 AM
  #60
Trader Rating: 31 (100%+)
Hobbyking.com Turnigy 4s for about $40!!! I have used them all season with no problems. I also have protek and maxamps and can't tell the difference.
Gearing should be ok but you want to find the gear that just barely tops out on speed by the end of your longest staight. Start there but you may have to drop a tooth or two on the pinion. Time yourself and drive like you are racing for about 6 minutes ands check temps. If you are over 120 degrees you might be geared to tall. Keep your eye on it. I wouldn't go with 5s or 6s unless you are just a basher not racer. Most tracks are 4s max and it's all the power you need and then a lot more. Anything more is just hard to control no matter who you are. Remember also that more cells means more voltage and power, not runtime. More runtime is achieved my lower kv motors and/or higher capacity (mah)
flysullivan is offline
