TLR 22T Thread
#4054
Do they make trailing spindles fot the truck? I know that the buggy and truck spindles don't interchange.
#4056
Casper tried your setup at the last race. All I can say is WOW , what a difference . I have a quick question why run buggy white springs in the rear instead of the ones for the truck?
#4058
What are the sticking points when building the shock on these things? Pun fully intended. I just finished building mine and the rear shocks are definitely not right. With the stock rear spring on it I can run the adjusters all the way to the bottom of the threads and still not get the rear up to recommended ride height. Off the truck, they cycle smooth but the rebound is sloooooooooow. This is with the stock pistons and 27.5w oil. On the track they are very harsh and the rear end slaps around all over the place. The front shocks work just fine. I have pulled them apart numerous times, sanded and re-sanded the edges of the pistons to verify the flashing is gone etc. I have built them with no rebound all the way up to the most rebound I could get out of them. I have tried bladders and emulsion style. What am I missing?
#4059
#4060
I have had a couple of guys look at them, they are just as stumped. I have built and re-built numerous shocks over the years and never had this problem. Whatever it is, it is even from side to side as verified by a shock balance tool. The arms are very free and I have tried running the mounting nuts and bottom bolts loose to the point of almost falling off.
#4062
#4063
#4064
R/C Tech Elite Member
As far as why you cant get ride height... IDK... I barely have to lowewr my collars, maybe 1/4-1/2" from top to get correct ride height on either of my trucks unless I am using buggy springs.
