TLR 22T Thread
#3751
Just picked up my 22T any tips/tricks? So far all I'm going to put on are the things I've done to my 22 buggy as well- bleeder emulsion shocks, front threaded upright hinge pin (forgot the name, haha), battery hold down, flanged wheel nuts, aluminum servo arm. That it so far.
#3753
#3754
For setup I've been liking Travis Brock's as a base but with the newer blue front spring, 3mm limiting, and 30 wt oil. In the rear I run the kit pink spring 1-inside shock position and 2 hole 1.55mm pistons with 27.5. I run on bigger indoor tracks that are usually well suited for 1/8th scale so I had to go up in dampening.
Sometimes I'll run 25/5 front kickup/caster.
http://www.tlracing.com/ProdInfo/Fil...ck.%20OCRC.pdf
#3755
Hey all, if anyone has an extra 22T manual that they could give me, it would be GREATLY appreciated! You may pm me. Thank you.
#3756
Moderator
You can download the manual and exploded views here:
http://www.tlracing.com/Products/Def...23#prodManuals
I print out the manuals for my different cars/escs/radio/etc and put them in a 3-ring binder for the track. The actual OEM manuals go into a file cabinet here at home for safekeeping. The binder makes for a great resource at the track
#3757
Yes, the original OEM black 22T book is the one I am looking for so if anyone has an extra/spare one that they are willing to part with, that would be awesome to help out a fellow RC tech.
Would be easier certainly and save on paper for sure.
#3759
You guys are very helpful. Gotta love the great atmosphere here to keep the ST class going from here into the future.
Hopefully someone has a spare one (22T manual) just in case though, lol.
#3760
#3761
I got that 22 platform manual memorized by now.
#3762
turning
i can not figure out why my 22t turns farther right then left
#3765
I actually busted a camber link last night at the threads. Ball cups stayed on, though!!!
