TLR 22T Thread
#2013
Yo D I built mine tighten back off 16th ran it once....retighten back off 16th....10 runs later butter smooth....all on kit parts
#2014
R/C Tech Elite Member
Its a lil hard to explain, as I was shown... You have to hold one wheel with one hand and give the other wheel a "flick" and if it rotates on its own more than one full revolution, then its too loose. Tighten and re-flick it...
The "goal" being 3/4 to one full revolution.
Also as I was told it is very finicky to changes... If the car is handling funky it is 90% of the time the diff or tire selection. I heard that the team drivers check the diff every run!
#2015
NEVER crank it all the way down!!!
Watch the videos posted at the top of the Electric OFF-Road section. " How to build a ball Diff" You will learn everything you need to know.
LINK read it
http://www.rctech.net/forum/electric...er-clutch.html
LINK read it
#2016
Thanks Clown, dang losi diffs seem very picky, the way I had it set was good for weeks, until new track with a double timing punch it section that slipped diff....have heard this diff has to be ran very tight, will have to rebuild and give the flick method a try....would be sweeeeet if losi came out with a prebuilt/pre broken diff....
#2017
I just tighten mine all the way. It was the only way I can keep mine from feeling gritty. AE I back off a tad, Losi I left tight. So far so good for now. But ill order spare rings and balls soon.
Oh yeah when I backed off, it loosened and lost consistency. Now it remains consistent and predictable. So I'll keep it locked for.now.
#2018
can someone tell me what turn mod motor to get for this truck? i've had a 13.5 mod motor in a t4 and wouldve liked more power. is 8.5 too much?
#2019
Big tracks or small tracks?
Low traction loose dirt or HIGH traction packed smooth clay?
IMHO if the track can take the HP then feel free to have fun, anywhere from a 10.5 to a 5.5 would be good if you can handle the HP that is. I have ran 10.5 and 8.5 but prefer the 10.5 for me (it had enough HP but not so much that I can get into trouble too much). 8.5 would be pretty good to!
#2020
mine
#2022
Are you guys using the 3" off the ground method for setting the slipper ? When I try it, the front end will lift briefly, then I hear the diff slip and the front end comes down, I have checked and rechecked the diff and if I try to spin it while holding the outdrives it won't budge, should I just tighten the diff ??
#2024
#2025
It all depends on the track or tracks you will be racing at...
