MMM IN VE8
Old 07-20-2011, 10:31 PM
buggy edp's Avatar
Default MMM IN VE8
CAN ANYONE HELP ME? CAN'T GET 2200 KV MMM TO FIT IN MY VE8....MOTOR STEM IS IN BATTERY TRAY.
buggy edp is offline
Old 07-20-2011, 10:33 PM
slashracer111's Avatar
Trader Rating: 25 (100%+)
http://www.rctech.net/forum/electric...uncements.html
Not large enough? Maybe it just needs to wrap around the entire page.
Lightly cut the end of the shaft off with a dremel tool and a cutoff wheel so it is not in the battery. You can use a light grinding wheel to clean up the edges.
slashracer111 is offline
Old 07-20-2011, 10:50 PM
buggy edp's Avatar
I WAS AFRAID THAT WAS THE ANSWER.......IS THIS THE NORM
Old 07-20-2011, 11:34 PM
YES it is normal
you also MUST use a HB pinion as they are thinner. The others will rub your packs
also dont buy the HD mount or whatever they call it, wont fit with a 2200
Silver04RS is offline
Old 07-21-2011, 07:13 AM
AZBOB's Avatar
i cant believe this has gone almost 10 hours
AZBOB is offline
Old 07-22-2011, 06:12 AM
buggy edp's Avatar
10 HOURS.. I MUST'A DOZZED OFF......OK OT THE MOTOR IN NOW ALL I HAVE TO DO IS LENGTHEN THE WIRES AND I AM OUT.
