Losi XXX SCB and Kyosho Ultima DB
I believe so. Looks like it's also based off of a short course chassis, and uses the same tires. Does it have similar wheelbase / track width dimensions?
truck with the body removed.
I race my SC-R with $60.00 worth of DB parts on it to make it a DB and
I love it. The thing rocks in the SC buggy class.
You can do thing same thing I did if you have concerns about the class
lasting. $60.00 is alot less investment to test the waters then buying a
buggy and having no place to race or sell it. It is less then 20 minutes to
convert it so you can run the SC and SCB class at the same race if theres
enough entry's to give you a few minutes to switch them back & forth.
Enjoy" I am"
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 42 (100%+)
yeah plus if the class takes off, you know Kyosho will re-think the DB..There are how many versions of the rb-5 Now?Point is Kyosho uprades when its needed..But yeah I say they are close enough that they should be in the same class.
