Traxxas 2wd Slash Thread
#2761
I don't have a yep gun yet but I heard the if u hold ur finger on it if u have to take it off with in 2-3 seconds it's two hot but when I get a temp gun what's the hottest I should let it get ESC and motor
#2763
Slash
Was looking for the thoughts on the RPM offset arm is it worth getting? I run 4 rear now to make offset right I switched the hex! Is that ox to do? Just now I don't have enough threads to keep rear tiers on keep coming loose need tips!!
#2764
Traxxas 2wd slash with Low Gravity Chassis
Traxxas 2wd slash low gravity chassis conversion /RPM Front offset compensate arm / rear 4x4 RPM arm / Integy Evo HD Alloy Gearbox / Castle Creations SCT combo /Gearing at 86T Spur 17T Robinson steel pinion / Aluminium front and rear hex / Traxxas Alloy Big Bore shock / rear arm guard from Stampede 4x4 / RPM Front and rear bumper with LED light / RPM Shock guard / Rear STRC aluminium shock tower / Traxxas Alloy turnbuckles / Louise Rc tires / Proline tires / Traxxas HD drive shaft / Future upgrade Hitec waterproof metal gear servo / Hot Racing alloy steering bell crank with servo saver . Past upgrade Fail : MIP HD steel drive shaft (Broke the shaft pin ) Broked drive / Idler /Diff gear due to plastic gearbox fail.
Now nothing break so far with these configuration I'm Hard Basher . SEGAR 1/8 track jump
#2765
Use back the original front hex when you use RPM front offset arm
#2766
Traxxas 2wd slash with Tamiya truck bodyshell
Got a spare Tamiya Mud Blaster bodyshell that's could fit on slash LCG chassis , it's works
#2767
2.8 Badlands on 2wd Slash
So I'm planning a new build and was wondering, would 2.8 Proline Badlands fit on a 2wd Slash?
#2769
#2770
#2771
Open motor
I'm looking to start racing a 2wd slash in open class and need a motor. What should I be looking for? 8.5 or 10.5 or ?
What other upgrades would one do? Besides lcg chassisknow that you can sink a ton of cash and end up with just a ok racer. But still want to race it.
#2772
Hey guys I have the traxxas LCG chassis on my slash, will it fit a 11.1 lipo?
#2773
Does anyone know if 4 rear offset 2.8 rims will fit on a 2wd slash with the protrac kit installed? Or do I need 4 front offset rims? Thanks
#2774
#2775
The Protrac kit does many things for you. It gives you stronger shock towers, a-arms, rear bearing carriers, turnbuckles, and a good set of wheels that are the same offset as Losi 10SCTE wheels, so finding premounts will be easy in the future. The stock Slash has different wheel offsets front and rear. Not the case with Protrac. Also, the kit allows for more tuneability. You can move your camber links up or down to move the roll center up or down to adjust to track conditions. You have additional shock mounting locations front and rear, giving you the option of having linear or progressive damping. Another cheap mod is going to the Slash 4wd steering bellcrank. It is stronger and adds Ackerman, which can help the truck turn better.
