1s 2wd setup
1s 2wd setup
I was wondering if anyone has tried a 1s setup for their 2wd buggys, instead of the usual 8.5 mod setup?
I am thinking about it, mainly so I can distribute the weight of my buggy 'where' I would like it.
The motor would have to be a much lower turn, say 3.5
I think that a 3.5T in a buggy on 1S would create a lot of heat, and not be practical.
Wattage (power) = Voltage times amperage, so to get the power of a 2S setup with half of the voltage, you have to draw twice the current that you would in a 2S setup.
I'm sure it's not that simple, but a 1S setup isn't practical, if it was, more people would do it.
You will need a very high C rating on the battery and will probably have a tiny pinion and a huge spur gear just to keep things in check. This means no low end power but a motor like that won't have it anyways. You are also going to lose lots of runtime.
I understand your thinking and appreciate the idea for what it is but I'm not sure how well it will work out in practice.
I'd stick with 2s.
A 5 cell Nimh setup was somewhat popular when brushless first hit the scene, but I have to agree that 1 cell lipo would not be enough. Maybe a better idea would be small, lower capacity packs run in parallel so you can place them in different locations.
Just like the others have stated, a 2s would be your best bet. A small 2s Reedy(#625) pack or similar would be fine, and would be somewhat 'movable' to try the different weight setups.
A 1s with a 3.5 would be decent, especially on a B4.1 or similar buggy on a 'diet' or 'lightweight' setup. I think the troubles would be to much though, maybe give it a try at least.
Keep in mind, you will also need a receiver pack to power rec/transponder/etc unless your on the new LRP's with built in boosters. Also, your charge times will be threw the roof, you will be using A LOT of the mah per battery versus a 2s. Some get away with running the same 2s throughout the day, just peaking it off between heats but this would be nearly impossible with a 1s.
Again, you can give it a shot and more power to you; but it has been tried and the troubles far outweigh any gains you may be getting.
