Tune With Camber Links >
Like Tree65Likes
Old 02-08-2014 | 01:41 PM
  #1621
henry's Avatar
Originally Posted by fredswain
It doesn't matter if it's a 2wd, 4wd, rear motor, mid motor, buggy, truggy, sct, 1/5, 1/8, 1/10, 1/12, 1/16 scale , etc. Balance is balance and this method automatically finds it and the behavior is always the same. A clue into your setup is that you should never have a higher weight oil in front than rear. If you do it's because you aren't running enough pack up front and need to go to smaller hole pistons. I suspect that while your springs may be balanced, your oil isn't. A balanced system won't have the same pistons front to rear since pack isn't only determined by the holes in the piston but also by the stroke length of the shock. These aren't equal. Due to these differences oil weights will be different as well. The drop test should work with oil installed too.
Hey Fred. I've been playing around w/ the RPM two-stage pistons on my SC10 that has the standard bore shocks.
Is their any variation involved when selecting piston/oil combinations when using these pistons?
henry is offline
Old 02-08-2014 | 01:51 PM
  #1622
RCmayor's Avatar
Originally Posted by Dnnap
Ok, thanks Fred!!
It's so far off across all possible spring combinations that it doesn't seem correct running very hard front springs and soft rear springs.
I could adjust the ride height, but I would have to run 35mm front and 20mm rear.
It just depends on what range the rear springs are compared to the front. As a comparison when I did some balancing on a serpent 1/8 buggy it took the hardest rear springs they make and one of the softest fronts. Your problem is exactly the opposite. Changing ride height definitely doesn't solve anything.
In your case the rear springs are probably in the heavy spring rate range so the softest is getting you close to where the hardest front springs are for balance.
RCmayor is offline
Old 02-08-2014 | 02:53 PM
  #1623
Dnnap's Avatar
I don't believe that is the case here.
• MUGE0574 - Front Spring (896 N/m) Very Hard 1.5/7.50T
• MUGE0562 - Rear Spring (699 N/m) Soft 86mm, 1.6/11.0T
If you look at the force rating for each, the front has 197N/m more force than the rear. This was the last combination of springs that I tested and the difference in frequency is easily noticed.
I have every Mugen spring made for this buggy, so it must be that everyone racing this buggy with Mugen springs are running a setup without balanced springs.
Dnnap is offline
Old 02-08-2014 | 03:14 PM
  #1624
RCmayor's Avatar
On my Serpent example even using the hardest rears and next to softest fronts, the fronts were still heavier than the rears rating wise. So with that combo you listed you probably aren't too far off. Maybe go to a different brand spring so you can go even softer in the rear.
RCmayor is offline
Old 02-09-2014 | 05:47 PM
  #1625
Riv2SC10's Avatar
From: In the Greater Ladysmith, WI metropolitan area
Has anyone not been able to balance the springs? I've got all available black and silver springs for the mbx6 and have tried all possible combinations as well as all shock positions and cannot acheive balance. Even if I go to opposite ends of the spring rates on front and rear. ie, if I use very hard front springs and stand the front shocks as vertical as possible and use soft rear springs and lean the shocks as horizontal as possible the rear will still spring up first. Both front and rear ride height is set to 27mm.
Any ideas where to go from here?
Keep in mind that if you are moving the lower shock mounting point inward on the arm, the wheel spring rate will end up lower, even if the shock ends up more vertical. The increase in motion ratio gained by moving the shock outward on the arm typically has a much higher impact than shock angle. Plus, it has an even bigger impact on damping because it not only affects the motion ratio(basically leverage), but it also has a big impact on piston speed, which affects "pack". Moving mounting point out on arm increases wheel rate and damping, while moving it inward on the arm does the opposite.
Riv2SC10 is offline
Old 02-10-2014 | 09:57 AM
  #1626
This must be a problem with 1/8 scale. The RC8 has the same problem. You can't balance it with the spring options they offer. You could release a new 1/8 scale buggy with balanced springs and people would think it was the best car ever!
fredswain is offline
Old 02-10-2014 | 11:09 AM
  #1627
do you mean the rc8, rc8b or rc8.2. i have had problems finding a balanced spring combo for my rc8be.
Cody227 is offline
Old 02-10-2014 | 11:29 AM
  #1628
Specifically the electric. I imagine it doesn't matter which version if they all use the same springs.
Old 02-10-2014 | 11:40 AM
  #1629
all 3 versions have different springs though you can use rc8.2e springs on a rc8be (they're shorter but have the same diameter)
Cody227 is offline
Old 02-10-2014 | 02:17 PM
  #1630
RC10Nick's Avatar
In the case of the sc104x4, I ended up running front springs in the rear because the rears just weren't stiff enough. Just because a manufacturer has an intended use for something, doesn't mean you have to use it that way!
RC10Nick is offline
Old 02-10-2014 | 02:21 PM
  #1631
turbo2cam's Avatar
is there a good way to bench test/experiment with oils/pistons/pack? (hell even droop/limiters) or any good reading on the dampening aspect of our shocks? I feel like i'm a bit lost when it comes to those things. it's such a daunting task to test at the track that I've never really done much testing...and now that I don't have a local track to test at....I'm looking for alternative ways of testing in order to figure out the cause/effect of changing the internal shock packages.
turbo2cam is offline
Old 02-10-2014 | 02:44 PM
  #1632
There is a way to balance pack however there really isn't a way to zone in on any required level of dampening without knowing what your conditions require.
Old 02-11-2014 | 02:59 AM
  #1633
You just have to buy other OEM Springs to get balance, at least that's what I did on my RC8.2E. Thought I had a great set up until I played with the springs to find a balanced set and wow what a difference. Losi and Kyosho have a wide range of springs. On the Tekno SCT410 thread here on RCTECH someone put together a list of all major OEM 1/8 scale springs and sorted the front and rear springs from lightest to heaviest. Great help in balancing 1/8th scale springs since my Tekno SCT runs 1/8th scale shocks. (BTW on the Tekno SCT410 its Green rears and Gray fronts that is working Plus 8X1.3 & 32.5 Wt in ft and 8X1.4 & 37.5wt in rear) - see Fred I do pay attention! Still working on the pistons and oil on the RC8E
John Wallace2 is offline
Old 02-11-2014 | 08:00 AM
  #1634
turbo2cam's Avatar
Yea I get what you are saying for sure. My problem is that I don't know what my conditions require either since all of the tracks that I travel too, aren't tracks that I get a lot of trigger time on. Since I don't have a home track anymore, I need to understand the shock tuning process better so that I can hone in on a shock package as quickly as I can before a race since practice/qual time will be limited.
what are your recommendations for balancing pack?
Old 02-11-2014 | 08:03 AM
  #1635
Here is a 1/8 scale spring chart. There should be enough options here to balance a 1/8 scale buggy.
