Wiring Help!
Old 05-16-2011 | 04:34 PM
JamminDriver's Avatar
Default Wiring Help!
Hey guys, I've always used pre-wired combo setups, but I want to install a Novak Ballistic 550 4.5T in my Jammin SCRT10 with a Castle MMPro. Can anyone tell me how the wires from the MMP match up to the Ballistic? MMP has a black, white and red wire. The ballistic leads are labeled C, B and A.
Sorry if I seem just totally stupid...I really don't want to mess up my new motor!!!
Thanks guys!!
KEEP THE RUBBER SIDE DOWN!!
JamminDriver is offline
Old 05-16-2011 | 04:37 PM
Manshoon's Avatar
I think the white is a common wire, keep that in the middle "B" and should be good. At least on mine, swapping the black and red to my knowledge, reverses the rotation of the motor.
Manshoon is offline
Old 05-16-2011 | 04:39 PM
So it won't matter which way I wire the black and red? It just reverses the poles, correct??
Old 05-16-2011 | 04:41 PM
Manshoon's Avatar
Yes
Manshoon is offline
Old 05-16-2011 | 04:43 PM
Yes
Thanks dude!!
Old 05-16-2011 | 04:57 PM
NO! If running sensored the wires must remain in the A B C order.
Switching 2 wires is only for non sensored systems. Very bad advice, hope it's not too late!
Dave H is offline
Old 05-16-2011 | 05:02 PM
Hohopirates's Avatar
Are MMP sensored? I thought Castle was not in the sensored game..
Hohopirates is offline
Old 05-16-2011 | 05:06 PM
Could be either:
Mamba Max Pro 1/10th Sensored & Sensorless ESC: Castle is Ready to ROAR
http://www.castlecreations.com/produ...a_max_pro.html
If he hooks it up sensorless then I'm out of line. But if sensored.....yikes!
Dave H is offline
Old 05-16-2011 | 05:15 PM
Good info.
Thanks Dave.
Old 05-16-2011 | 05:19 PM
No, not too late. But I'm confused now because the MMP has a black, white and red wire for power leads. The ballistic motor is has the terminals labeled C, B and A. So, which goes to what??
Old 05-16-2011 | 05:22 PM
Originally Posted by Hohopirates
Good info.
Thanks Dave.
Note that it's only the ESC that can go both ways...the CC motors are sensorless...
Old 05-16-2011 | 05:23 PM
I don't know the wire colors and I'm not going to guess. Should be an A-B-C label somewhere. Snip from the manual:
Let’s get started:1. Connect your motor to the ESC:Sensored operation requires you to connect the three motor wires to the ESC in the correct order. Incorrect connections on a sensored motor will cause abnormal operation and there is a strong possibility of damage to both the motor and speed control. Your sensored motor will have the wires marked as A, B & C. The Mamba Max Pro motor wires have the same markings. Plug A into A, B into B and C into C. For sensored operation, be sure to plug the motor’s sensor cable into the sensor port on the side of the controller.
Again, only an issue if you are running sensored, with the sensor harness connected, etc.
Dave H is offline
Old 05-16-2011 | 05:30 PM
Oh, I feel so stupid...this makes perfect sense now...I couldn't see the forest through the trees...the Novak motor leads don't go "in order" so I didn't recognize the labels as A-B-C.
Problem solved!! Thanks Dave!!!
Old 05-16-2011 | 05:54 PM
Everybody is welcome, hope I was able to help some.
It’s a common mistake. Castle has a lot of very satisfied sensorless users, understand many don’t have any experience with sensored. Hope I didn’t come across too harshly.
Cheers
Dave H is offline
Old 05-16-2011 | 06:27 PM
corn_bread's Avatar
i have never had a issue with being sensorless
corn_bread is offline
