4x4 SCT Clay Tires?
I run at OCRC which is a high bite clay track and I use Gold compound JConcepts Barcodes. I'm currently using the stock foam that they come with, but I'm really curious to try out the AKA Red foams with the Barcodes. I've also run the AKA Wishbones but didn't like them nearly as much as the Barcodes. You can also try out the Suburbs 2.0 in the MC compound. I know some people that have run them, they liked them, but still came back to the Barcodes because even though the tread is nearly identical, they just didn't feel the same.
SK gave some good suggestions, but the best thing to do would be to ask the fast guys in that class that run at your track what they use.
I ran the AKA Wishbones and Panther Switch SCs, both worked pretty well. This was at IRCR last year and the more the track wore in, the better the tires worked as they wore towards slicks.
I like AKA wishbones super soft for indoor clay.
In my Hyper 10SC, Jammin SCRT10 and Losi SCTE in leisure hours here in Joliet, IL which is a high bite usually sticky clay track.....The main tires I've tried have been bow-ties in M3, AKA Wishbones, Gold Barcodes, the new Suburb 2.0's and Clay compound Panther Switch 2.0's!
So far the barcodes, suburb 2.0's and panther switch 2.0's are all awsome.....on any day any of these tires they are awesome....if it's wet the Wishbones are unstoppable.....
I would get a set of wishbones and either suburb 2.0 in clay compound / or panther switch 2.0 in clay....that way your covered in wed/medium and dryer situations.
Jason
Jason
I wouldn't say they suck. When I ran them, I did feel like they weren't as consistent as the Barcodes. I felt like I didn't know how they were going handle from turn to turn, on some turns they'd oversteer, then on other turns they'd understeer. I just never got the feeling of knowing what they were going to do. Each turn was surprise. The forward bite on the other hand was very good. I was running super soft in the rear and soft in the front which was suggested to me for our track. But I got tired of not knowing how to drive my truck from turn to turn. The Barcodes have just as good forward bite and are WAYYY more consistent in the turns every where on the track. Wow, after re-reading my post before hitting submit, I guess I agree with you afterall But seriously, they're 10 fold better than the stock tires, but not nearly as good as the Barcodes, at least for our track.
i like panther switches. they last a good while and get great grip.
