Pro-line New Flo-Tek Short Course Body!
#196
You know, setting the "flow through" feature aside, its a great looking body! Proline did a nice job with it.
#197
Hey guys can someone tell me which holes in the front of the Flo Tek are for the SC10 body posts? I had originally cut it for the SC R but i just switched brands and dont remember what hole are what. Any help would be appreciated.
#198
In the picture below you can see the dimples in the hood on the right side. They might give you enough reference to determine which one is for the SC10? Also the alignment to the vent grid might help. Mine is mounted on an SC10.
#200
I'm at work, but I'll check tonight if no one responses before then...
#201
http://www.youtube.com/watch?v=KYw-6gI21Vg
I have tried their way and it works but you have to be careful cutting with the exacto. I have had the exacto slice past the vent area into the body trying to force a cut. I have found it easier to make the 4 corner holes in the vent with a body reamer large enough to fit body scissors. I then cut the vents out with the scissors with more control. Then I clean and smooth everything out with a dremel.
#202
R/C Tech Elite Member
Proline has a video on Youtube.
#203
For anybody wanting a little Pro-Line equipment they are donating $.50 of every dollar made to charity for the month of December from web and call in orders. Got to say that is a great thing and I pulled the trigger yesterday on some stuff I had been looking at. Way to go Pro-Line.
#204
I've not seen any three-views of the Flo-Tek body. But, they may be out there. I have seen them for other bodies. Hopefully, someone will post one. Have you emailed Pro-Line directly?
I've found that even with using three views, I rarely SEE the body that perspective in real life after I paint it. So, I try to keep that in mind. I like building scale models, so using three-view outlines was my natural approach as well.
Here's a link to my airbrushing page if you want to see some of the ones I've done. Might give you some ideas of what you like and don't like.
http://www.indyhobbies.com/Airbrushing.html
#206
My front hole is the one closest to the front bumper. I could three dimples between it and the windshield.
On the back side, the hole I reamed is the one closest to the rear bumper. I count two dimples between the hole and the vents behind the cab.
Hope that helps! If your body is clear still, you can set it on the chassis and confrim that it all lines up and that the wheel wells are where they should be.
Scott
