My New Truck?????
My New Truck?????
I am putting together a completely new truck. It will be an associated t4. It will have a tekin 8.5 turn brushless. ESC will be a Xerun 120A. High Torque Servo. 2.4 GHZ Controller. Custom Painted Body. Aluminum Upgrades as needed, and a few different tires. Thoughts on anything i might possibly want to change or add?????
Dont get to carried away with the aluminum. The only stuff I woudl look at would be front c-hubs and steering knuckles, as well as the rear hubs. Thats what I had on my SC10 and it worke well. Definately look into titanium turnbuckles though, they are worth the money.
Just a tip when you build the truck, put a drop or two of 50 wt shock oil on the gears in the transmission before you close the case. Dont get to wild with it, but a little bit really quiets the truck down and helps it run smoother.
Good luck!
Good luck!
