AE diff/shock silicone for XRAY
Hi, the differential fluid of XRAY is 14,49$ for 35 ml (10,000 cst - XRA359310 ) and Team Associated 2oz (50 ml) is 3.69$ (10,000 cst - ASC5455).
I think I will use AE, I think there is no such a big difference in silicone quality. Someone tried?
Also same for shock oil (600cst = 45 wt 14,49$ vs 3,29$)
There is a difference in how they rate the weight for the oils. CST ratings are more consistent than WT. If you compare Associated 35wt to Losi 35wt, they aren't the same. There's a chart somewhere that someone made showing the differences and how they fall under the CST rating. I've always run Associated oils but as I run out, I'm replacing them with PT Racing oils. Cheaper, comes in a larger bottle 4oz, uses CST rather than weight, and quality seems to be right there with every other top brand or maybe even a little better. To top it off, the guy that owns it is a local racer and I'm all about supporting the locals.
I use associated diff oils. Good stuff. I'll probably switch to their shock oil too now if they are going to be labeling it in CST.
xray 600 cst is equivalent to 35wt associated more or less, I had a table more exact than this one but could know where now
3w.twf8.ws/php/index.php?option=com_wrapper&Itemid=175
3w.rctech.net/forum/attachments/electric-road/468987d1245915795-300-shock-oil-equal-what-wt-shockoils-comparison.jpg
(can't post images or url's yet, someone could if they want)
