Pro-Line's February 2011 Releases!
#31
#34
That sounds like a good setup for those conditions, but the Gadiators weren't meant for a clay track. They would work OK but the Suburbs 2.0 would be better in those conditions.
#35
So something was changed to get rid of all the slop in the sc10 front end set up? What can I do to get a replacement part or parts?
#36
What's wrong with the inboard axles? Mine had bad slop after a month, but after replacing the bearings they're nice and tight.
#38
#40
#41
#42
Ahem- cough, cough... releases are up now at www.prolineracing.com
sweet now i just need to place an order!!
#44
Impossible to set camber and toe when there is 3 degrees of slop. If they are updating something they must have realized something was wrong.
#45
Available now: http://prolineracing.com/performance...haft-kit-rear/
http://prolineracing.com/performance...aft-kit-front/
Uses locknuts instead of e-clips, which is much better.
