2wd Slash steering pins
Anybody know of a stronger replacement for the stock Slash steering pins, #3640, 26mm. These are the only ones I ever bend when I race and am getting tired of straightening or purchasing an entire pin set. Thanks.
Wow you are bending those? You must be running insane speeds to bend those. I have yet to bend any of those. Mine always just back there self out in the rear.
I dont know if they are any stronger but I went and got some pins for the ruslter that are E-clipped on both ends for my slash. I didnt buy this whole kit just the 2 rears I needed.
http://www3.towerhobbies.com/cgi-bin...&I=LXVAH4&P=ML
Added note, these are the vertical pins that run up through the front bearing carriers. Mine have never backed out w/ blue loctite applied. Will the Rustler set you mentioned fit this? I purchased the Lunsford pin set for the Slash, but it doesn't come with the vertical pins, just the horizontal hinge pins. Thanks again.
