Savox Problem
Savox Problem
hey guys, fairly new to the sct scene.
Ive been spending bit of time and money on my Sc10, i have bought a 12Kg didgital Savox servo and it seems to be playing up ?
Every time I turn suddenly and hold left/right the servo seems to surge/cut continuesly ????
I can turn slowly and it is fine ?
If i am accelerating and turn suddenly at the same time it will surge both steering and the throttle ??
Im running a dx3s radio. The F Rate is 11ms lowest radio can go.
servo specs:Weight (g)52.4
speed 0.08. (does that < mean that my radio is to slow)
torque 12
thanks, kyle
torque 12
thanks, kyle
yeh ive got hobbywing 60amp speedy
ok thanks heaps ill give that a go
its just the sensorless ?
my mate has the same and his seems to be fine and his a 35a speedy ??
So what ESC should I be running do you think ??
im looking at some castle bec's on ebay from like 10A and up what amperage shoulld i need, sorry about the questions just not that up to date with all of it
The 10A bec is the most common, It will power it no problem. Have you made sure your steering endpoints aren't to wide? just a thought, it pulls a lot of current when steering is fully locked and the servo is still pushing.
Yeh just set to 50% and still surge's
if i add the 10A bec will it draw more battery power causing less run time or will not affect running time ?
Cheers
Will i find them on ebay?
+1, the servo is not receiving enough power to operate correctly. Adding a Rx capacitor will solve you issue. Spektrum makes a great one for about $6 (SPM1600) part #.
cheers for posting
another question (sorry) but I was given a 7.4v 21kg Savox servo aswell i put this in my hyper 10sc with a venome 13.5t combo with 35A speedy and it seems to be a little slow ?
is that just how that servo is or will that capacitor fix that aswell ?? I have read that they are a high torque fast servo ?
cheers, Kyle
cheers, Kyle
