? about foam inserts
Hey guys, I was looking at some foam inserts and I found a couple that I could not find a seem on them. did they cut these out of a block of foam or did they just do a great job of gluing the seem? Thanks
You use it as a hole punch. Put it on the foam and wack it with a hammer. Cut's perfect donuts. You can make your own tool and make your own foams on the cheap. Got a few in the garage for certain things. Thinwall steel tubing works well.
Maybe the bigger tire co.s have a simple punch press for this.
I'm sure there is even weirder ways to make foam donuts I'm missing......
I think some of the shaped foams are injection molded foam. Two dies get filled with allmost liquid foam, then clamped together giving that weird seam.
From: Conducting aggressive board meetings at my local track
