t4 tire question help
hey i am new to the sport, and i have a t4 with the castle creation brushless setup, but anyway, i was noticeing that some of the guys at the track in my class had the same tires all the way around the truck..i currently have the caiber tires on rear and stock tires up front.. is there any more tire combo i need to no or which is a better combo?
It depends on your track surface as far as what tires to run. At our track, guys will run Pink Taper Pins all around, or Taper Pins rear and Pink Directionals in front, or Suburbs all around, etc, etc. You need to talk to to the guys at your track to see what tires/combos you should run.
just ask Q's and im sure they will help u anyway they can...
