Like Tree1Likes
B44.1 Thread
Old 03-03-2012 | 07:32 AM
  #1501
SpraydbySprague's Avatar
From: Conducting aggressive board meetings at my local track
Originally Posted by crashnburn
I always thought that the NTC3 one way diff fit the 44.1 since it has the longer out drives instead of the TC3 diff. Am I wrong (again) ?
You're right, the NTC3 HD one way is the one that works best with the B44 and 44.1 cars. The tricky part is finding one. I believe AE discontinued them.
SpraydbySprague is offline
Old 03-03-2012 | 07:49 AM
  #1502
Matt Trimmings's Avatar
Originally Posted by mikesd1980
What size wheel wrench do these take? Dont like the plactics one that came with it.
The nut is a 8/32...The driver is a 11/32.
Matt Trimmings is offline
Old 03-03-2012 | 03:42 PM
  #1503
mikesd1980's Avatar
mikesd1980 is offline
Old 03-03-2012 | 04:19 PM
  #1504
JakeC351's Avatar
Hey guys about to order some koyosho springs and want to know which ones I should run for a med to low traction track. Pretty technical a few jumps.
Jake
JakeC351 is offline
Old 03-03-2012 | 04:29 PM
  #1505
Jake
I was told that most run the yellow front / white rear combo.
Old 03-03-2012 | 07:53 PM
  #1506
Grouchman's Avatar
+1 ..... Yellow front and white rear
Grouchman is offline
Old 03-04-2012 | 12:42 AM
  #1507
-WHEELMAN-'s Avatar
I'm running green fronts and white rear. Absolutely love them wont change. Medium to high bite medium to large indoor clay track. Think it will be perfect in tight tracks as well no push to the front end what so ever!!
-WHEELMAN- is offline
Old 03-04-2012 | 06:56 PM
  #1508
idrummerboy13's Avatar
blue front, yellow rear. Blue barcode front, green v2 rear. Corner speed is so incredible i beat my last week times by a lap, last week i was getting around top 5 now top 3. I keep getting more attached to it.
Is it me or i have a hard to make my wiring pretty? its a pain in the ass! Some1 post a pic up of some clean wires!
idrummerboy13 is offline
Old 03-04-2012 | 09:00 PM
  #1509
-WHEELMAN-'s Avatar
Old 03-04-2012 | 09:04 PM
  #1510
does anyone make any aluminum shock towers for these bad ass lil buggies yet? i have cracked both of my shock towers (relative nube) and am trying to keep costs down/breaking stuff down to a minimum. thanks
klopsided6r is offline
Old 03-04-2012 | 09:55 PM
  #1511
Grouchman's Avatar
Nice job!!!!!! Wheelman
Old 03-05-2012 | 08:00 PM
  #1512
Default b44.1
hows this? transponder kinda ruined it! lol. ill figure that out later.
Old 03-06-2012 | 11:32 PM
  #1513
MOmo's Avatar
I haven't seen an Aluminum one, but are you running a doubled up tower on the front? i bought 2 CF towers, added a little CA, ran screws thru the 4 corners of the tower and tightened them down. Once dried, I gently sanded around the edges ad then CAed the edges of the tower to make sure it wouldn't splinter.
The rear I just left the single tower. I have taken some pretty brutal crashes and towers are holding just fine.
MOmo
MOmo is offline
Old 03-07-2012 | 02:57 AM
  #1514
MOmo
Hi, could you show a pic of this? I'm just curious.
from_Poland is offline
Old 03-07-2012 | 11:46 AM
  #1515
-WHEELMAN-'s Avatar
LOOKS GREAT!! My transponder is under the center drive shaft between the receiver and the servo.
