need help with xxx-t mf2 setup >
Old 09-18-2010 | 04:57 PM
Default need help with xxx-t mf2 setup
I am running the "stock" setup on a medium bite hard packed dirt track. It doesn't seem to matter which tires I run. The front pushes all the way through the corner - on entry, middle, and exit. I need more front grip! Any suggestions?
thanks for the help.
getting faster is offline
Old 09-18-2010 | 05:04 PM
Briguy's Avatar
Try Casper`s setup for the XXX-T CR and just adjust MF2 rear .
http://www.petitrc.com/setup/losi/se...etup200905.pdf
Briguy is offline
Old 09-19-2010 | 09:07 AM
I will try that. What adjustments will have the most affect on front grip?
Old 09-21-2010 | 10:55 AM
XXXDad's Avatar
R/C Tech Elite Member
Lightbulb
RIDE HIGHT,CAMBER,ADD WEIGHT NEAR THE FRONT!
XXXDad is offline
Old 09-21-2010 | 11:27 AM
Davidka's Avatar
If you're using a setup known to be good (the "CR" setup or Casper's) and the right tires and are still not getting steering, check your drag brake setting. Brushless systems can have VERY little drag brake effect if it's not set correctly.
Davidka is offline
