SC10 Factory Team Kit
I just got one and truthfully I don't see that much difference from my kids rtr 10. yea you get different shocks, a ball diff, motor sink, battery plate, pretty blue screws, a clear spur cover and some other little things. People that I know who have up graded from there sc10 rtr to the FT truck already have some of these parts. So is it really worth it? I can see one big difference, its NEW
In less there's some major difference that I don't see, if you get a ball diff and shocks or have the shocks its about the same to me.
Uhhhh, thanks for nothing. You wasted your time for that rather than to say left or right? Wow...
It doesn't say anything about it as far as I can tell. Unless it's hidden somewhere in the manual. On the build instructions itsays nothing.
Me too I didn't see which way it should go in? Anyhow, mine ended up being on the left side and the diff seems to be fine. I don't think it really matters cause either way you still have to take the camber link\wheel off to adjust on either side.
I put my access screw for the diff on the spur side since that is the side I have to take the wheel off of to change anything as far as gearing goes,I did it mainly so I wouldnt forget what side it was on.
http://www.teamassociated.com/pdf/ca...tb4_manual.pdf
My apologies...it does not state which direction it goes in. Typically you want to put it in on the driver's right position or spur gear side. i had to go back to the FTB4 instruction manual to verify this. The other direction could possibly loosen your diff screw.
Thanks for the heads up. Looks like I'll have to take the transmission apart and flip the diff over.
I just built 2 FT SC10 and I found it odd they don't show you which side put the diff. screw on. Maybe they decided it doesn't matter. I've always put it on the spur gear side though, as stated above.
