mini revo problem
Have you checked your slipper clutch? I had a MERV that did the same thing on a 3S; the slipper was not tight enough and actually ended up melting the pad. Once replaced and adjusted correctly, it was a rocket!
SoCal
SoCal
If it still has good top speed and the motor winds up but it just doesn't move fast it's the slipper.
If it just all around lacks power it's probably in training mode.
Also check the driveline for binding and if it's none of those your esc may be shot. Mine fried and still worked but just barely moved the truck.
