Matching up wheels and tires??? >
Old 08-03-2010, 02:16 PM
Default Matching up wheels and tires???
I've been looking through the Tower web site trying to get some wheels and tires for my new RC8Be but I can't figure out how to match up the darn things. How far off in mm's is acceptable between the wheel size and the tire size?
I'm thinking about getting Pro-Line Road Rage Street tires (if you have better choices for street tires I'd appreciate any suggestions) which are:
http://www3.towerhobbies.com/cgi-bin...7&I=LXMW85&P=K
79.50mm (3-1/8") x 47.75mm (1-7/8") x 107.94mm (4-1/4")
but some of the wheels are:
85mm (3.3") x 41mm (1.6")
http://www3.towerhobbies.com/cgi-bin...7&I=LXNS41&P=K
Or
86mm (3.38") x 41mm (1.61")
http://www3.towerhobbies.com/cgi-bin...7&I=LXTTC2&P=K
How close do you need to be with tires and wheels measurements; is a few mm's off OK?
Also, some wheels are 18mm hex vs the 17mm; is it easy to make this adjustment if I want the 18mm hex wheels?
Thanks in advance for the help.
MulliganAl is offline
Old 08-03-2010, 06:30 PM
brickshouse's Avatar
just compare with what comes with the car and go from there, the wheels are 83mm and 17mm they make a taller wheel to give a stiffer sidewall, for high bite tracks
brickshouse is offline
