Savage Flux ESC help!
Ok seriously trying to figure out how to tame a Savage Flux for a four year old.... Cant it be setup to run slow by holding the trigger some how while i switch on the truck at a 1/4 trigger pull to set it up so NO WIDE OPEN THROTTLE?
Do the calibration, and when you "adjust the throttle", just pull it back a tiny amount. Same with reverse. Not sure if that will work, but it's worth a try.
Or you can go into the ESC settings with the USB or the Car editor, and find the relative setting. I don't own the USB/editor myself so I'm not sure.
You need to get a Castle link and get set up to connect esc to your PC. Castle's latest FW update has some easy to use options to help.
Set punch control to 80 - that will slow down the response, but not top speed. I think the new torque control can slow it down, just make sure you reset punch back to zero.
