Originally Posted by neospirit
(Post 7704933)
I just called Tower and the lady said the next shipment date from AE is 8/27.
jb |
I'm looking at getting a few of the Turnigy 5000mAh 4S 40C Lipo Packs but they are 149mm x 37mm, does anyone know it this will fit in the RC8Be battery tray?
Also, if I go with the Turnigy 5000mAh 6S 40C Lipo Pack will it fit at 149mm x 49mm x 52mm? |
what chargers is everyone using for their rc8be? im thinking of getting the new lrp touch when it comes out.i want to charge at 5.5 amps continuous! alotta guys at my track are charging at 5 amps but only getting 3.2 constant charge rate.
Chargers!
I have a megapower charger.
I charge my batteries from 12 to 20 amps. The problem is getting a good Power supply!?!?!?!? Don't know why they have high powered chargers and no power supply to feed them. But if you want a simple and easy charger no power supply get the dynamite passport ultra, charges up to 8 amps and good customer service from horizon. But if you want to be a little cooler check hobby King and they have some really good chargers but you will need a power supply. try this: TURNIGY MEGA 400W Lithium Polymer Battery Charger http://www.hobbyking.com/hobbyking/s...attery_Charger Power supply:20A twin 12v switching DC Power Supply for Chargers http://www.hobbyking.com/hobbyking/s..._for_Chargers_ This is my charger:Mega Power Gemini-2014 Duo 600W Charger http://www.miracle-mart.com/store/in...oducts_id=4099 The new nano batteries from HK can charge at 5C!!!~!!!! |
Batteries
I run the Nano Tech as stated before.
But you have to modify the Rc8be tray. HK has the 6000mah battery at 170mm + but I actually got a chance to measure them and found this is not accurate. They are roughly 155mm, a tad to long for our trays. But dammit I want to run these batteries so a cutting I go.... Tray: http://lh3.ggpht.com/_7Jbf17GxhUk/TF...2015.29.18.jpg http://lh3.ggpht.com/_7Jbf17GxhUk/TF...2015.29.44.jpg Battery in tray: http://lh3.ggpht.com/_7Jbf17GxhUk/TF...2015.38.07.jpg Sorry don't know how to attach in those nice little boxes that explode!!!???? These batteries are awesome and they are not the best batteries they have. They have some higher "c" rated (dishcharge rate) batteries The battery tray will hold a 140mm battery(stock unmodified). I run the 3s batteries I have a four cell same size (length) |
Pics
Thought you might want some more photos
Leodis don't get mad at me. (can't see the attachment button) With 43 tooth spur, 18 pinon, 2650 and lots of dirty dirt! http://lh6.ggpht.com/_7Jbf17GxhUk/TF...2015.49.41.jpg http://lh3.ggpht.com/_7Jbf17GxhUk/TF...2015.49.20.jpg http://lh5.ggpht.com/_7Jbf17GxhUk/TF...2015.49.01.jpg |
Originally Posted by kaisertrip
(Post 7770774)
I
The battery tray will hold a 140mm battery(stock unmodified). thanks for sharing the specs. |
(Post 7767957)
Are those the AE aluminum steering knuckle or the integy ones?
I love the elite mount. but the high temps here in Texas are killing me and my buggy!!!! I charge my batteries from 12 to 20 amps. The problem is getting a good Power supply!?!?!?!? Leodis don't get mad at me. (can't see the attachment button) |
Originally Posted by MulliganAl
(Post 7770972)
Man, that sure messes up my plan for a Turnigy; I was hoping it would fit without any mods but the Turnigy is 147mm long. Bummer
thanks for sharing the specs. http://www.hobbyking.com/hobbyking/s...dProduct=10869Turnigy I have a 5400mAh 35c protech that is $140 I use this in the mains it has more punch. This is noticeably faster than the turnagy it is the best power I have seen without spending well over $200 The quality look and feel is impressive. http://www.amainhobbies.com/product_...-ROAR-Approvedprotek |
In stock at amain.
http://www.amainhobbies.com/product_...-1-8-Buggy-Kit In stock at Stormer hobbies https://www.ssl-stormerhobbies.com/c...ns&pn=ASC80904 |
What pitch and other spec information do I need to order a few different size of pinion and spur gear to tweek my new RC8Be?:tire:
Originally Posted by Pacesetter
(Post 7771935)
I have been running the Robinson Racing pinions and have had good success. I know a few people who are running the Novak and the Integy pinions and like them. |
i usually run the losi mod1 pinions they're a bit shorter but work fine
I run the HB pinnons. They feel smoother and little quiter. I am also running the RR 43 Spur gear.
Any ETA on when the Elite mount will be in stock again? And anything else I should know for must do mods? Ordering one this afternoon.
| All times are GMT -7. It is currently 05:55 PM. |
