RC10B4.1 FT/WC
#6436
No problem.
There are only two arms still produced for the T4.1/SC10 these days. One being the same carbon style as the B4 arm, and the other a plastic material the same as the B4.1. However before the T4.1/SC10, there was a plastic arm made a bit stiffer.
The top arm is carbon, signified by its very light color.
The middle arm is T4.1/SC10 arm. It is quite dark in color. If you look closely there are little circular indents from the mold on the top, as well as the outer most webbing is a bit thinner than the carbon or older plastic arm.
The bottom arm is the older plastic. It is darker than the carbon, however lighter than the plastic. The outer most webbing is thick like the carbon arm.
Thx Chris! Much appreciated.
Since Stadium Truck is kicking off again, hoping you can provide us with some of the setups from the Reedy Truck race this past weekend. The only recent setup is Thielke's Surf City '11, which appears to be an unconventional setup, in which slicks were used.
Thx again!
#6437
Bigger B4.1
Mommy-Mommy I want one but they are sold out!!!!!
Waaa-Waaa!
http://www.teamassociated.com/factor.../details/9636/
Waaa-Waaa!
#6438
No problem.
#6439
Waaa-Waaa!
Waaa-Waaa!
#6440
Has anyone heard when AE is going to start shipping the new chassis?
#6445
Any way to modify the existing bodies to fit the "Stretch B4.1" chassis without them looking stupid, or should we all just plan on buying new bodies? (Parma says thank you, JConcepts says thank you, Pro-Line says thank you...)
#6446
My Proline Bulldog body fits just fine. It is not the new 8mm body.
#6448
I have a cut down t4 chassis to 8mm and my old bodies work as they are held on with velcro I don't use the body pins
#6450
Kit body on mine, fits just fine
