RC10B4.1 FT/WC
#6242
Hopefully this Saturday I will be able to try out some big bores on my b4.1! From ones who have tried, could you tell a noticeable difference?
#6243
hey guys, like to ask if anyone on here runs a 13.5 lrp x12 in a b4 with a lrp sxx version 1 esc/no advance timing! i need to find a starting point for gearing! if u dont know what pinion/spur, i'll be fine with a good starting FDR. the motor has the 4 dot timing insert in it, i also have the 3,2,1 inserts also. i usually run mod buggy, but like to try some slower for a small indoor track any help would be awesome.
#6245
ran a d3 9.5 in the t4 at 84/22, and a d3 10.5 in the b4 at 81/24.... both where coming off under 100 deg after 7 minute runs... cranked up the timing this morning, see what happens at practice tomorrow, still might gear up some.
really making me want to get an esc that i can boost with... still using older gtbs
#6246
i was running 13.5 novak no boost at 75/30 usually in the 142-144 range after 7 minute main (with a few practice laps)
#6247
Just finished installing .5 degree AE hubs and man did they create some undesirable slop in rear hubs to arms. Drilled and tapped holes for 5-40 set screws in bottom of hinge pin bosses in hubs and nice and tight again. This should have been done by AE. I guess they are wanting hubs to wear though so they can sell more
#6249
Super Moderator
Trader Rating: 31 (100%+)
Run a 7.5, if an extra 3/4 of an oz. put you down on power that much, you didn't have enough to begin with.
#6251
Super Moderator
depending on motor temps you could add 1-2 teeth on the pinion as well as your new found radio setting
#6252
looking to buy a used race ready b4.1. How much should i expect to pay?
#6254
I'm new to the hobby so i need radio and all, so rtr. 17.5 class
