RC10B4.1 FT/WC
7678 is the older standard size ball diff, this was included in the original b4's and used the 9574 transmission case with 3/8x5/8 outdrive bearings. The ASC9853 diff was originally brought in as an upgrade for the SC10 (which uses the 9826 trans case and newer metric 10x16mm outdrive bearings). So you either need ASC9574 and bearings or the 9853 diff kit.
Will the 9574 tranny fit in my car?
Yes the 9574 trans case will fit in your car.
I believe they just went to a different bearing mainly, there isnt any issues with running the older diff, might be a bit harder to source parts down the line but that would be it. the only difference is the outdrives, the diff internals are the same.
ah yes, instead of picking up the whole 9853 diff to drop into you current setup you could just get ASC9852 and rebuild your current diff with these outdrives, everything will transfer over.
Since I have the bigger tranny and 10x16 bearing, what I notice is my Team Associated Differential Kit (old b4 one) is a weeee bit smaller on ONLY the outdrive cups which is the reason they don't sit in the bearings correctly.
So to solve the easier way, I can just get the bigger outdrive cups to fit the 10x16 bearing, but is the part where the balls contact the disc of the outdrive cup any bigger or smaller?
The other way is either I can get the whole SC10 Ball Diff Kit (which I don't want to do since I already built the one I got) or I can get the old b4 tranny and smaller 3/8x5/8 bearings, correct?
I use Amain to check part compatibility. Search a part number, then it lists on the description page what vehicles its compatible with. Very helpful
This is the way you want to go, the diff rings are the same. The only part you will need to change is the outdrives
For example AMain states that the 9853 diff kit is only for use in the SC10 when in fact it will work in the B4.1 and T4.1 kits.
Yes the outdrive was enlarged to fit the larger bearing, just the part that slides through the bearing. The diff rings and the remainder of the diff are the same.
