RC10B4.1 FT/WC
With Sandy coming in and work being closed I am going to have some time to go over the used buggy I just got. What is a good base set up to use for indoor clay? My buggy currently has losi bb springs Red fronts white rears. I would like to stick with those springs for now if they are the correct ones, so I am looking for oils pistons, camber locations, shock locations, etc. Also, what about the rear ballast weight...should it be used for clay?
im in the same boat as you minus the bb springs an mine is a b4, just go to associateds site and look at the set-ups that they have posted
Sorry for breaking the rhythm of this velcro conversation , but i wanted to get feedback from anyone that has been successful in getting their BB installed in such a way that they don't rub on the turnbuckles? If so can you please explained/show your configuration? U have clearance, but I'm sure as soon as I hit the track my shock bodies will be toast.
Cleaned off the chassis with some rubbing alcohol and it seems to be holding. I'm going to go take the body off and on 50 times to see if it holds. Stress test!
run that setup and then play with the links and tires and also battery postion. If you can tell all the setups are so similar.
Sorry for breaking the rhythm of this velcro conversation , but i wanted to get feedback from anyone that has been successful in getting their BB installed in such a way that they don't rub on the turnbuckles? If so can you please explained/show your configuration? I have clearance, but I'm sure as soon as I hit the track my shock bodies will be toast.
The place I used to work used those same plugs. Could believe it when I came across them. Needless to say I snagged a handful. I'll try to find out where they came from. They have to be available in bulk somewhere. Just a matter of finding out where.
http://www.mocap.com/sheet-metal-hol...-standard.html
