RC10B4.1 FT/WC
your running stock or mod?what motor and gearing?im running the x12 17.5 but wanna try some sportsman mod,also your running k springs? what piston and oil,i wanna make it out on a sunday to run triple a's,i really wanted to run the classic but my birthday or my wife birthday always falls on the date,I'm going to try and make it down to sdrc in octorber for the race for the cure,grandma died of cancer last year and i wanna try and run that race.
Orion R10Pro in Blinky Mode
72/33
Orion VST Pro 17.5 with timing turned all the way up (ballistic)
TrackPower 4400Mah 50C Lipo, or Reedy 4000 60C
Setup Wallnuts and myself settled on.
Front K Pink 30 weight No. 2 pistons
Rear K gold 25 weight No. 3 pistons
Carbon Front arms,
Carbon Top plate,
Carbon U-Brace unshaved, .030 washer under ballstud.
Plastic rear hub towers second hole from inside (B4.1 manual setup),
ride height 24 all around.
0 degrees toe,
1/2 camber all around,
Shorty Lipo just slight forward of center in battery compartment,
In a word, Dialed.
Carbon B4 stiffest and best for very high traction conditions
B4.1 Softer then carbon best for med traction
B44.1 softest , best for low traction
I have had those in the know claim different ....
Not a 100% answer , sorry ..
personally use B44.1 arms on low traction.
Some of the confusion is B44.1 arms use to be made of the original B4 plastic.
They have now switched to the the B4.1 plastic a while ago ...
Still, examine the two arms and notice the B44.1 arm is thinner & trimmer ..
Think some of the confusion is the B44.1 arms use to be made of the original B4 plastic. They switched to the the B4.1 plastic a while ago ...
Can examine the two arms and still see the B44.1 arm has thinner & trimmer braces...
Not around here at TRCR .....
also not arguing with respectfully
Everyone of our Ae team drivers* ?
Switched & use the B44.1 arm for our slippery brand new layout last week...
*me too
Now only wondering when to go back to B4.1 & the carbon later yet
*me too
Maybe its the humid weather in washington.. it changes the molecular structure of the plastic
We haven't had rain in over a month!
Not typical tho... We have a 1 month summer... It's called august. Haha
Dont the team drivers always run the b44 rear arms? High bite, low bite? Maybe not blue groove though. I would assume carbon would be best.
Big Bore Spring Effects
I searched, but I am not sure I found the answer to my question...
If you convert to big bore springs, does this take away some of the "slap" from big jumps? Or does this merely take away the rubbing of the springs on the shock bodies?
Thanks,
JB
Thanks,
JB
IMO, wouldn't say it takes away the slap but there's definitely less progressive feel of the springs. Sounds like a setup issue for the track...
