RC10B4.1 FT/WC
20/81 is boosted.
So I am sitting at work, bored out of my mind, and I down load the B4.1 FT manual to check something out. I notice that the gearing chart has changed compaired to the regular B4.1.
The WC and Team kit say to run a 20/81 spur and pinion but the regular says 28/75 for a 13.5 brushless. Both of the FDR's are the same. So why the change? Possibly to move the motor further back? Or did the tranny gear ratio schange?
and
30/75 on another track.
both 13.5T blinky mode
i was running a 72/31 and i was talking with ron and he told me to gear it 75/31-32, what difference did you feel between the two gearing?
I was just thinking that when I looked at the manual it had a ** talking about boosted for 17.5 and 13.5
I didn't notice any difference there but then again the track I run at is a small indoor clay track and the newest layout there was no straight (track is being redone and being built bigger) long enough for me to test out the top end on either gearing....So I geared for more torque......
So I just glues a tire to my forearm........lol. I glued up some tires, set them one my table the put my arm down to try and use the heat gun trick to true my ribs. When I lifted my arm 30 seconds later, it was acetone time.... sigh
72/29-31 13.5 boosted is some great gearing . Gear for the track size !
Oh and the Pro-Line and JC Hex Adapters Are BaumB just dont Muscle them tight .. I like blue so highly doubt I'd by the Avids ..
Wildcat, I sent you a PM.
