RC10B4.1 FT/WC
Old 07-19-2012 | 01:40 AM
  #16816
Just got my b4.1 worlds built, first it ran sluggish, then watched the how to build diff (thanks vid poster) and tighten the diff bit more, now no sluggish but does wheelies, lol! i got a 7.5 tekin on 22gear, is it the best way on the tekin pro esc to just turn limiter from no limit to 80% limit to stop wheelies or is gearing better more efficient?
Vinno is offline
Old 07-19-2012 | 05:51 AM
  #16817
The diff and slipper do complete different jobs. Diff= differential as in the one in the back of your truck. This diff let's the inside tire and outside tire spin at "diff"erent speeds as you go around a corner. If you make it tight the it is more like having a limited slip, better strait line traction less diff action around a corner which results in less steering.
If you set your slipper like I do, tighten the nut all the way down and then back off 1/2 turn. Set your diff up like the book said 1/8 to 1/4 back off this will give you a set up for a med to high traction track. In a low traction track you may want to loosen the diff 1/8.
The slipper protects the gears in the trans from a on power landing, too tight and the motor will try and spin right through when the tires can't turn an then you are buying new gears and may be motor.
jayhart76 is offline
Old 07-19-2012 | 06:00 AM
  #16818
derekbsmith's Avatar
Originally Posted by CHIZZLE
Has nothing to do with torque. Diff tightness is strictly side to side. Basically, it's how easy(loose diff) or hard(tight diff) your rear wheels spin in relationship to each other. And how easy the power from your motor is transferred to the unloaded wheel. Your slipper is just a breaking point or clutch, if you will, between the motor and transmission.
respectively it has to effect something (speed, torque) with the transmission b/c now after tightening the diff I can do wheelies on demand and its much quicker!? the slipper nut should be .5mm from flush, never more b/c we want it to slip? thx!!!
derekbsmith is offline
Old 07-19-2012 | 06:21 AM
  #16819
The manual instructs you to tighten the slipper so that .5mm of the shaft is sticking out past the nut. I always start there plus a quarter turn.
For the diff, you tighten it in increments of a quarter turn. To test your set up Break in the diff per many of the guides found on the internet, then place the buggy on a table and hold both rear wheels down. Blip the throttle on your radio. What happens? If you hear a barking sound and can feel grinding when you hold the wheels then the diff is too loose.
If the front wheels dont come off the table at least an inch tighten your slipper a quarter turn. Check again and adjust until the front wheels come off the ground about an inch or two for loose tracks, and 2 to 3 inches for high grip tracks. Works for me.
zipperfoot is offline
Old 07-19-2012 | 06:28 AM
  #16820
I had Steven Hartson set my slipper at the past JConcepts Summer Nationals. I use to always set mine so it raises about 3 inches. Hartson set it so it instantly pops up about 10 inches when given full throttle. Track was med/high bite. He said thats his normal setting for all tracks.
SAGISI is offline
Old 07-19-2012 | 06:47 AM
  #16821
this front-wheel trick is as old as dirt, but thanks!
Old 07-19-2012 | 08:22 AM
  #16822
All the way down as in what...the slipper spring fully compressed? cant be!
Old 07-19-2012 | 09:27 AM
  #16823
jf+'s Avatar
jf+
Thanks, zf..
Yeah I was referring to using the slipper trick (holding the wheels and gunning to get 2-3" of lift in the front) in my earlier posts. I wasn't getting lift, and started to hear the diff slipping (so I stopped immediately). I believe you've confirmed my suspicion that the diff is too loose. I'll tighten a little and see if that gets the front to raise properly.
I never had this issue before, always was able to tighten the slipper nut until the front raised.. The nut was usually about 5mm past flush (yes, 5). But, I just rebuilt my diff, broke it in, can lightly flick the rear wheels and they spin 1 revolution. I thought this was money. But when I went to set the slipper, this weirdness ensued. Won't slip, won't lift. I thought it had to do one or the other.
Like I said, I'll tighten the diff a little and test a few times to see if that's the issue. If that doesn't do it, I'll have to just starting drinking. More.
Right now the car runs great (turns very well, seems to have plenty of get-up and go) but I haven't been to the track.
jf+ is offline
Old 07-19-2012 | 10:18 AM
  #16824
That is what gives me 2" off the table when holding both rear wheels. I tighten the slipper all the way and the back off 1/4 to 1/2 turn
Old 07-19-2012 | 10:41 AM
  #16825
Wildcat1971's Avatar
I get 3 inches with 2 threads showing. weird.
Wildcat1971 is offline
Old 07-19-2012 | 11:40 AM
  #16826
davidfast's Avatar
It really depends on how wore / glazed / un-glazed your pads are
davidfast is offline
Old 07-19-2012 | 12:02 PM
  #16827
tedstryker's Avatar
Need help ...
This is the second time this happened in less then a months time..left side rear cva has way to much play its destroyed 2 bearings already and tubes inside the carrier..
1 why is there so much play ..left to right?
2 what's causing damage to the tube...
It's not from over tighting...
tedstryker is offline
Old 07-19-2012 | 12:07 PM
  #16828
STLNLST's Avatar
His set up worked well in mod and 17.5 We wont have traction like that again until the next time at Outback so that slipper adjustment will have to wait
STLNLST is offline
Old 07-19-2012 | 12:15 PM
  #16829
lol, my pads are 8 years old.........
Old 07-19-2012 | 12:17 PM
  #16830
Originally Posted by tedstryker
Need help ...
There is a lot of play because the alum hubs are trash. Wait wait dont kill me everyone. They should have used set screws to snug them up and they need to be shimmed. And... the bearing are loose in the hubs, not a great fit/finish. yes you can use tape on the bearings to make them seat better, yes, you can drill the hubs and tap them, but seriously, they should have been designed better. How are you destroying the crush tubes? That is impressive. I have destroyed a lot of rear bearing over the rears and never ever messed up the crush tube. Hell i raced for 2 months on bad outside hub bearings and the tubes were fine.. had to throw away the plastic hubs though, the outer race melted into the hub (old style crappy plastic hubs).
