RC10B4.1 FT/WC
They are turned inside out... They are older proline holeshots with the middle cutout to get the pattern I wanted. Also to fit on the front rim... I am testing this on different hard packed surfaces for future developement.
What do you guys think?
As for the question on the tires....
Have any of you tried the Blue Aluminum shock caps and tapped them to make them threaded so they would be bleeder shock caps? I never understood why they have not made aluminum bleeder shock caps. There must be a reason?
I plan on running the Avid Springs and Collars. I know Avid does not have the cups yet, so are you guys using the TLR cups?
http://www.amainhobbies.com/product_...Cup-Set-TLR-22
ETA and Avid releasing the cups?
As for AVID Cups?? Not sure of release date!
just did a +8mm conversion to my trusty b4 also got the +8mm body and waiting for it to come back from the local painter .will run my current set up and see if any adjustments are needed .has anyone else done the conversion if so was there any set up changes to be made
also has anyone tried a big bore shock set up????
