Novak Havoc Pro SC ESC Thread
#31
inst mine last night.
when in reverse it is nothing or full throttle. I tried everything to get this fixd but hopefully novak will help today.
It also shut off at 125* motor 110*sc with "0" timing and 12/54 gearing testing only in the street w/spare tires.
More concerned about the heat than reverse though.
other than that ...seems great.
#32
Company Representative
I have forwarded your comment to Engineering; if you need additional assistance, you can always PM me.
#33
What motor are you running and what's the overall gearing (transmission ratio). If you're running something hot like a 4.5 the gear above is probably a little over the top.
#35
Will the Ballistic 550 Brushless Motor 4.5 work with a regular mamba max? Not pro. I burned up my 5700 and eventually want the whole SC system but I can't afford the pakage right now.
#36
#38
the Nova link will not work with the Havoc Pro only with the Knetic
#41
ESC for my FTb4.1
NovavTwo or anyone, I am getting back into electric 1/10 buggy and want to get a new esc to replace my GTB, I was looking at the MMpro and stumbled onto this thread, I have always been a Novak guy with the ocasional lrp. But I like orange. My question is how does Havoc pro sc compare to the MMpro? I want timing advance, which is why I am wanting something other then my GTB in my B4.1. It will most likely be 13.5 turn motors allowed, can you please shed some light for me, I would like to stay Novak. Thanks a bunch. And the kinetic is a little more then I want to spend, unless it will make a difference for what I want to do.
#42
Our new Havoc Pro SC has 8 levels of dynamic timing (including "off" for ROAR Sportsman) that can be adjusted without requiring a PC interface. This controller features the same low on-resistance as our GTBs.
For more info, see our full Havoc Pro SC information. Pairing this esc with either our completely re-buildable Ballistic 540 or Ballistic 550 makes an unbeatable racing combination.
#43
#44
Might pick up a second one to replace the stock esc in my Salsh 4x4 with a 5.5 550 ballistic as well.
#45
We definitely recommend the larger 550 size motors in the heavier SCTs such as the Slash 4x4. We do offer stand alone Ballistic 550 motors; however, we only offer the 4.5 motors in our two 550 systems
