lipo and charger ?
lipo and charger ?
ok, eventually im going to buy lipos for my rustler. what is a good charger with a balancer built in? affordable, not like $150. and what is a good 3s 5000mah or higher lipo? whats the biggest size i can fit in the battery location without having to cut the back wall out?
Turnigy, Zippy or Flightmax for the battery.
They have several chargers. These chargers are the same as many other companies stick their name on and charge 2-4x as much for them.
www.hobbyking.com
They are good value for money and the batteries are good quality from Hobbyking. 15c I'd say is a bit low to be honest, I'd go for atleast 20c. They do a 5000 3s 25C Flightmax for $37.20 which will be good (can't post a link as I don't have enough posts sorry)
Might be a bit of a squeeze in the rustler though so may require the expansion kit.
A 50watt charger will limit current when charging a 3S 5000mah liposince a 3S takes more power that the charger outputs. You need to get something with at least 100watt of output power or be satisfied with your 3S charging taking longer to finish charging.
Are you looking for a DC or an AC/DC powered charger? That will decide which ones are possible charger's you'd be interested in.
Then you'll want an AC/DC charger. Its the only kind that'll do both.
There are a lot of 50watt AC/DC chargers, but only a few that have 80watt or more. The Dynamite Passport Ultra is an AC/DC 100watt charger ($130). The TritonEQ 2 is also a 100watt charger ($200).
Hyperion is upgrading the power in their 0606i chargers to 80 or 90watts, but I don't know when those are going to be available, prehaps in June?
I've bought from both RCMart and HobbyKing. I prefer HobbyKing, prices seem to be better. Service has been about the same for me from either.
