Brushless motor current draw
#16
While a boat is technically "Off-Road" you probably won't get the answer you are looking for here, as this is a car forum. You might have more luck here.
The prop also play a part. The faster the hotter n more amp draw.
#17
This thread was super helpful and made me look this up:
http://science.howstuffworks.com/env...uestion501.htm
Power via volts is more efficient than power via amps.
#18
The 2200kv motor will draw more current because it has a higher power rating. Gear ratio does not matter because it has no effect on the power rating of the motor.
Power = voltage x current
