Novak Havoc 3s/HV4.5 First Test
When Novak announced the 550 Ballistic motor for 4x4 SCT classes thier literature stated that this motor is compatible with the Havoc Pro, HVPro, Kinetic, and the Havoc 3s. All but the Havoc 3s are rated at 540 amp/phase current so I would not expect any issues. The Havoc 3s is rated at 120 amps/phase which seems low for the HV motors. Since I already had a Havoc 3s I decided to get the HV4.5 and try this.
I have my motor/ESC mounted into a Jammin SCRT10 with the stock 13t pinion. I changed the base set-up that comes with the Havoc 3s a bit to my liking. I prefer to manage EXP in my radio and not the ESC so I set the throttle curve to linear. I also reduced the deadband a bit.
I was having some issues with my set-up which I finally corrected by replacing my receiver after installing an external BEC. Novak Tech stated that the BEC should support my JR 9100s, AMB PT and 30mm fan but I was having voltage fluctuations during my initial testing. The External BEC fixed some of my issues but with my S3000 receiver glitching the results were the same. During heat races my ESC was resetting and steering was going. I will test without the external BEC soon to see if the Havoc internal BEC can handle my set-up.
Temps were very low everywhere. My ESC was very cool and I never measured more than 100 deg. The motor was warm to the touch after 10 minutes running on my Gravity Hobbies 5000mAH/40C battery.
If you have a Havoc 3s it will work with the HV4.5 motor. I may try the Havoc Spec with the large capacitor to see if this even works. I was very satistified that this worked without issues. I have been looking at many of the newer ESC with more PC programming options. I have been waiting to see what the Kinetic is like. Since I have not chosen which one I like better I can race with the Havoc 3s now.
I noticed the capacitor on the Havoc Pro SC is larger. I will check this out and post.
Not to thread jack...
Im running a 9100s in my buggy and I am getting into 4wd SCT.
I have had TONS of issues with sprektrum and these vehicles??
What are your findings running high power servo's, high power systems, and PT's all at once and having issues with glitching??
and hope to read more from you.
I've had issues with my 3100 and and old light grey case, and two transparent ones.. not sure of the number.
I was told the 3500 works great??
I have had different ESC's also so I do not believe that is the case. Thanks for the info.
I ran the MMP w/ my 4.5HV and was a little disappointed with the results. I switched to a Havok Pro and like this set up much more.
It is much smoother, easier to understand and reprogram to changing conditions and allows me to leave some my adjustments on my radio.
Thanks for the info on the 3s. I too look forward to the SC specific ESC
Now if you still really want to get rid of it... I would buy it off you for a fair price. Let me know how much you want, I would not mind having a spare.
Gary
I posted in the Jammin SCRT Thread about my issues. The S3000 Reciever can have some issues with glitching if it gets dirt inside. I have also heard that hard impacts can cause issues too. It had issues even with a stable input voltage from an external BEC. So I swapped in a S300 and I have been OK since then. I had forgotten that this reciever had issues on me before and probably made me send my ESC to Novak when it may not have needed any upgrades. Anyway, I talked to a few guys at the track when I was having issues and they asked me if I was using the S3000 receiver from Spektrum. "You know the one in the grey case"!! And they also had many issues when using higher current servos with extra gear connected. I will open the case and see if I have debri in there but I will not install it in a race vehicle again. I don't think this is generically all Spektrum receivers, just the S3000.
I tried to connect my Havoc 3s without the BEC again using the S300 Receiver and had some glitching so I am sticking with the External BEC for now.
The Havoc 3s ran great without issues and was cool after 5-10 minute runs. I'm so glad I didn't upgrade yet. I am very interested in the new Novak Havoc Pro SC.
