8th scale brushless motor question
So i was screwing my neu motor to my motor mount and I saw that the screw went all the way down into where the copper wires were
on closer inspection i saw that it went about 2-3mm into the wire and even broke one if the wires.
Is this motor toast? is it safe to run? will it short? will it be as fast?
has anyone else ever done this and still ran their motor fine?
If the risk is minimal ill just run it but if its bad ill send it into neu to get it fixed
I would send it in to Neu, it needs to be repaired or replaced. Email them with the same information you gave here.
