LRP SXX Stock Spec offroad setups
With the new batch finally shipping I figure it would be nice to have a post dedicated to the Stock Spec. Setups and advice
I ordered two on Thursday and received them Saturday. Tuesday will be the first time on the track with them. I have two RS's at Tekin right now for repair because they will not work with the 203 software. As soon as I get them back I will do a comparison between the two on a small indoor clay track in a SC and RT5. I will keep what works best for me.
Any advice for "feel" and "boost" on the LRP running a 17.5? Where should I start with the gearing?
Damn I didn't know these were avail yet. Who has the best price?
One question can the RS or RS Pro check the motor temp like this supposedly can?
Yeah that's what I thought but wasn't sure about the temp check I like the idea of the speedo being able to do that it pretty cool and probably more accurate.
Oh nice! I love my SPX speedos for off-road, but I hear the tekin murders it on-road.
I'm sure the SXX SS is gonna be sweet!
I got me a SXX SS today should try it out friday in a buggy with a 13.5.
Well after a little testing for Cactus it appears at this time that the best gearing I found for 13.5 is 22/81 and 10.5 is 21/81. All of which with 4 dot timing. Dont go past Boost level 4, or it is VERY hard to predict the power band for jumps and so on. X-12 Stock Spec motors were used for these test's.
Hope this helps some of you.
Thanks Scott. Have you had any issues with a cog or hesitation running the x-12's?
My settings:
SC - 24/78, 3*4*4*3, Orion V3 17.5 w/ two marks of timing
RT5 - 24/76, 3*3*4*3, Orion V3 17.5 w/ neutral timing
i just installed this sxx stock spec in my b4 today.went to the track and all i can say is that this thing is a rocket!! it feels like my old b44 with a 6.5 turn. im running a x12 13.5 and its brutal power once the boost kicks in!! the temps were a little high untill i lowerd the pinion a few teeth. im running 23/78 and temped at 115-120 after about 10 min.esc temped around 98.you really gotta watch the gearing with this thing because itll definitely fry a motor if your not carefull. i would suggest nothing past 4-5 dot for boost levels on the speedo!!
With my original SPX Stock Spec I never really ran higher than 4 or 5 mainly due to a lot of instant punch and it wasnt as smooth. This led to increased motor temps as well.
Dont assume that you can just go to the highest level, it WILL affect temps and most of all traction hehe
