Need a good shock setup for slash >
Old 02-19-2010, 11:31 AM
Suspended
Trader Rating: 7 (89%+)
Default Need a good shock setup for slash
Looking for any info or good setups for shocks and springs for traxxas slash 2wd. Also any good battery info also
diesel32x is offline
Old 02-19-2010, 11:51 AM
Krawl's Avatar
Front 50wt, Rear 40wt, stock pistons and stock springs
Krawl is offline
Old 02-19-2010, 12:32 PM
Big Bores all around, stock springs; 40 wt ft -50 wt rear
bowl806 is offline
Old 02-19-2010, 12:40 PM
GLwagon's Avatar
Trader Rating: 22 (100%+)
what surface?
rough/smooth
big jumps/little jumps
high traction/low traction
GLwagon is offline
Old 02-19-2010, 12:43 PM
I figured he wants to know just for GP.
bowl806 is offline
Old 02-19-2010, 01:25 PM
Suspended
Little and big jumps, dirt track so a little rough in spots and smooth in straigh aways.
Old 02-20-2010, 12:25 AM
so far ive been happy with 40 front no preloads/50 rear large preload, 2 hole pistons. sometimes when it lands a little funny in the front i wish i had a heavier weight but when i do it gets a little twitchy on the straights with little divits on it. but im still fairly new to the track so take it with a grain of salt.
RocktechRC is offline
Old 02-20-2010, 04:27 AM
Suspended
Can spring rate and travel help with that
Old 02-20-2010, 05:11 PM
I have been running the Slash since it came out and the best setup I have found for a fast hard clay track with some descent jumps is 40 up front with quarter inch PL and 60 rear with threequarter inch PL all progressive and one hole pistons.
-B-
By the way.. If you jump big, replace the shock caps with metal. The plastic cant handle a hard hit.
Krown Kustoms is offline
Old 02-20-2010, 08:17 PM
Suspended
How about the proline shocks? Are they worth a shit or just like the big bores?
Old 02-20-2010, 08:41 PM
Ridley's Avatar
They are real nice, but they don't tune themselves. Still have to try different oil to see what works best for you....it's all about personal "feel", and has a lot to do with all your other suspension settings.
Ridley is offline
Old 02-20-2010, 09:02 PM
Suspended
What about springs? I know different color springs have different pressures?
Old 02-21-2010, 09:06 AM
I like big-bores with RPM 2 stage valves and 40wt. And it's better to use a linear spring. I use Losi 3.2 rate on rear and 3.7 on front. Of course tire selection could change your setup as well.
jmaverick is offline
Old 02-21-2010, 09:24 AM
carguy's Avatar
Trader Rating: 15 (100%+)
Default PE 4X4
U have part #s for these springs????
carguy is offline
Old 02-22-2010, 02:10 PM
Sorry, I had to dig through my parts, but the rears are Losi 5156(3.4 rate) and the fronts are Losi 5134(3.8 rate) and are available at Horizon Hobbies. I also have used Associated springs, but they fit a little tight on the big bores. Actually I have a large selection of springs for tuning, cause they're cheap.
