Schumacher CAT SX2 4WD buggy Thread
#496
Just picked up one of those yesterday. Are the rear shocks supposed to be in front or in back of the shock tower?
#497
Hall oaloksatoor,
your SX2 Mod looks interesting. How ti drive compare to SX3?
#502
has anybody used the tough racing belts for the sx2 ? ive bought some for my xx4 and looking for feedback on quality ect . cheers
#504
Time to wake up an old thread.
Looking to get my SX turned SX2 race ready soon.
I am in need of a setup that will be good for out door dirt with medium traction and dust off line. I will be running a 5.5t LRP motor and an LRP speedo.
I have the big bore shocks, I have printed off one of Si Moss's set up sheets for high traction clay, but think I will need something more suited to outdoor lower traction conditions.
I hope someone will have a setup or a place to look for one, for this older car.
#506
Sorry for late reply - try to look into these setups http://www.petitrc.com/setup/schumac...cherCatSX.html
Sometime what is medium/high grip for one is low/medium for another in his eyes so it's difficult to have definite answer which setup will be best for you
#507
#509
hey i have some drive shafts and hardware for sale if you need them
http://www.rctech.net/forum/r-c-item...iveshafts.html
#510
SX2 with saddles
hi, i just want to share my SX2 mod to saddle packs battery. The reason of doing this was that i had pleny of saddles (for my other two B44&B44.1) and only one punched Lipo stick for my SX2... Therefore i got an idea to adopt saddles to my favorite Shumi car :-) BElow is the result. The only one disadventage i can see so far is ESC's fun which i had to shift a bit, and mount only with two screws... i need to think how to fix it.
For this mod i used one LiPo strap (right side) and LiPo posts taken from my B44 :-) Second strap was made by myself. I had to move it up a bit to make a space for belt bu placing some 3mm rubber as a spacer.
Regarding the weight balance i'm not sure if it is perfectly adjusted as now i have one battery, servo and "part" of the motor sitting on the right side... but anyway i enjoyed this work.
as this is one of my first post here i cannot insert direct links yet, just copy below and paste into browser: imageshack.us/g/1/9868594/
cheers
cheers
