Durango DEX210 Thread
Hi!
I'm new to posting here, I've been searching and searching and I always end up here in rctech and I just can't help myself, I really like the look of the dex210 and it seems like a nice car...
I don't want to race, requires a lot of time/money that I'm not willing put onto it, but I would like a fast buggy to play around...
How fast do you think this buggy goes in the rtr version? I just saw one in the sale trade area and looks like a good deal...
Where should you place the caps?
They slide on over the outdrives and gives dust protection for the outdrive bearing, I belive they are meant to meet up with the optional dust boot as well to create a good overall protection.
Durango
Can Someone Please Pm Me And Tell Me How The Hell YoU Get This Car To.Turn... Thanks
make sure your steering endpoints are set correctly. make sure there is no bind in your steering rack. make sure you're using the proper front tires for your track. make sure your ride height is set properly. make sure your servo doesn't suck. If you're racing the RTR, take out the servo saver.
couple things you could try (not all at once); move your battery forward, lower your front ride height a mm or two, softer front spring, less castor, shorter front links, angled front links, more toe-out.
find a good tuning guide and learn how to figure it out yourself.
And next time, ask a little nicer. You're not entitled to a response from anybody here so don't sound like a spoiled kid when you ask.
Just picked up a rtr 210 on eBay cheap. Is it worth it to spend the money on the aluminum chassis or is the stock rtr chassis half decent?
If I were to change chassis in your place I would upgrade to a dimec spec B chassis or the dimec20 spec B, which actually is almost as stiff as an alu version. The spec B versions are a little stiffer, and more durable than the original spec. But start with using the stock chassis, it is definitely good enough.
If you are dead set on an alu upgrade I would go for a longer version of the chassis, we are using the RDRP +11 which is really good, but it costs some $$
I just started my new home made chassis. It is going to be a dedicated mid motor only setup. It will allow saddle packs or a shorty. I am of the opinion that if you are running a MM car in lower traction situations, you need to run saddles. If you are running high grip or stock blinky class you want a shorty. Well see how well this works out and if I'm right or not.
We have played with a shorty in the dex as well using the normal chassis, but never really found a setting that was universally good, have had the best results with a full stick, so it will be really interesting to see what you come up with.
This will be interesting, really looking forward to reading your analysis of the outcome. As a note I can say that here in Sweden we race almos exclusively on carpet during the winter season, and a lot of kits seem to have good success with a saddle pack configuration. There are kits that work well with a shorty as well, but they have primarily a DB2 or TM2 type of configuration with the motor on one side and the shorty on the other. This is all mod since stock classes aren't run in Sweden.
What Are Spare Parts That Will Be Really Needed At The Track
I would not spend money on the stock alu chassis. The stock rtr chassis is definitely ok, especially if you are racing on low traction. The stock alu is also 8mm shorter than the rtr chassis, so the car will be a lot more nervous.
Here is my chassis, just finished the proto. Hopefully ill make it to the track this week to test it. If it works like I hope and there is interest ill make some more!
That's pretty much how I'm doing mine except I'm not using aluminum.
